سلام این کد مربوط به mmc هست نمیدونم ایرادش کجاست کسی میتونه ایرادشو بگه؟
#include <mega32.h>
#include <stdio.h>
// Alphanumeric LCD Module functions
#include <alcd.h>
#include "ff.h"
#include <delay.h>
// Timer 0 overflow interrupt service routine
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
// Reinitialize Timer 0 value
TCNT0=0xD8;
disk_timerproc();
FATFS fs; // Work area (file system object) for logical drive
FIL ftest;
char buffer[20];
void main(void)
unsigned int bw; // File R/W count
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: 7.813 kHz
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x05;
TCNT0=0xD8;
OCR0=0x00;
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Timer1 Overflow Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x01;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Alphanumeric LCD initialization
// Connections specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
// Characters/line: 8
lcd_init(8);
// Global enable interrupts
#asm("sei")
lcd_puts("salam");delay_ms(5000);lcd_clear();
f_mount(0,&fs);
f_open(&ftest, "read.txt", FA_CREATE_ALWAYS | FA_WRITE);
f_read(&ftest,&buffer,15,&bw);
lcd_puts(buffer);delay_ms(5000);lcd_clear();
while (1);
