پاسخ : کتابخانهآای برای چیپ AD7780-AD7730
من با این کد این آی سی رو درایو کردو و زمانی که به ورودیش صفر ولت میدم صفر رو ارسال میکنه اما زمانیکه ورودی بیش از صفر میدم خروجی های غلط ارسال میشه.
// AVR Core Clock frequency: 16.000000 MHz
#include <mega16.h>
#include <alcd.h>
#include <stdio.h>
#include <spi.h>
#include <delay.h>
#include <stdlib.h>
#define ADC_RESET PORTB.3
#define ADC_CS PORTB.4
#define ADC_DRDY PINB.2
#define high 1
#define low 0
void adc_init(void);
unsigned int read_spi();
void main(void)
float resultf;
PORTB=0x00;
DDRB=0xB8;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: Off
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud Rate: 9600
UCSRA=0x00;
UCSRB=0x08;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x67;
// SPI initialization
// SPI Type: Master
// SPI Clock Rate: 1000.000 kHz
// SPI Clock Phase: Cycle Start
// SPI Clock Polarity: High
// SPI Data Order: MSB First
SPCR=0x5D;
SPSR=0x00;
lcd_init(16);
adc_init();
while (1)
resultf = read_spi();
printf("Data: %d\r",resultf);
delay_ms(500) ;
void adc_init(void)
printf("Please wait\r");
ADC_RESET=low;
ADC_CS=low; //Set low to AD7715 chip select low pin
ADC_RESET=high; //Set high to AD7715 reset low pin
ADC_CS=high;
delay_ms(3000);
ADC_CS=low;
spi( 0x10 );
ADC_CS=high;
ADC_CS=low; //Communications Register
spi( 0x7C); //250Hz update rate
ADC_CS=high; //Setup Register info here
printf("Calibrated\r");
delay_ms(1000);
unsigned result;
while ( ADC_DRDY);
while (! ADC_DRDY );
while ( ADC_DRDY );
ADC_CS=low;
spi(0x38);
ADC_CS=high;
ADC_CS=low;
result=(unsigned) spi(0)<<8;
ADC_CS=low;
result|=spi(0);
result=(unsigned) ((unsigned long) result);
return result;
