Pixel storage
In uncompressed BMP files, and many other bitmap file formats, image pixels are stored with a color depth of 1, 4, 8, 16, 24, or 32 bits per pixel. Images of 8 bits and fewer can be either grayscale or indexed color. An alpha channel (for transparency) may be stored in a separate file, where it is similar to a grayscale image, or in a fourth channel that converts 24-bit images to 32 bits per pixel.
Uncompressed bitmap files (such as BMP) are typically much larger than compressed (with any of various methods) image file formats for the same image. For example, the 1058×1058 Wikipedia logo, which occupies about 287.65 KB in the PNG format, takes about 3358 KB as a 24-bit BMP file. Uncompressed formats are generally unsuitable for transferring images on the Internet or other slow or capacity-limited media.
The bits representing the bitmap pixels are packed within rows. Depending on the color depth, a pixel in the picture will occupy at least n/8 bytes (n is the bit depth, since 1 byte equals 8 bits). The approximate size for a n-bit (2n colors) BMP file in bytes can be calculated, including the effect of starting each word on a 32-bit dword boundary, as:
, where the floor function gives the highest integer that is less than or equal to the argument; that is, the number of 32-bit dwords needed to hold a row of n-bit pixels; this value multiplied by 4 gives the byte count.
, where height and width are given in pixels.
In the formula above, 54 is the size of the headers in the popular Windows V3 BMP version (14-byte BMP file header plus 40-byte DIB V3 header); some other header versions will be larger or smaller than that, as described in tables below. And is the size of the color palette; this size is an approximation, as the color palette size will be bytes in the OS/2 V1 version, and some other versions may optionally define only the number of colors needed by the image, potentially fewer than 2n.[2] Only files with 8 or fewer bits per pixel use a palette; for 16-bit (or higher) bitmaps, omit the palette part from the size calculation:
For detailed information, see the sections on file format below.
کسی میتونه بگه که اینا یعنی چی ؟؟؟؟
