سلام وقت شما بخیر
یک برنامه برای رمز و تغییر آن در کد ویژن نوشتم ، اما error که میده رو متوجه نمی شم چیه
ممنون میشم اگر راهنمایی کنید
قسمت مورد نظر برنامه
void check( unsigned char key1)
unsigned char b;
switch (Page_numb) {
case 0 :
if(key1==14) // setting
Page_numb = 1;
lcd_clear();
lcd_putsf("Enter password");
if(key1 ==13) // show pass
Page_numb = 1;
break;
case 1 :
if(pass_length == 0)
lcd_clear();
//sprintf(b,"%d", key1) ;
lcd_putsf(key1); // lcd_puts(b);//
pass[0] = key1;
pass_length = 1;
else if(pass_length == 1)
// lcd_puts(key1);
pass[1] = key1;
pass_length = 2;
else if(pass_length == 2)
//lcd_puts(key1);
pass[2] = key1;
pass_length = 3;
else if(pass_length == 3)
//lcd_puts(key1);
pass[3] = key1;
pass_length = 4;
else if(pass_length == 4)
if(pass[0]==saved_pass[0] && pass[1]==saved_pass[1]
&& pass[2]==saved_pass[2] && pass[3]==saved_pass[3])
lcd_clear();
lcd_putsf("right Pass");
delay_ms(500);
lcd_clear();
pass_length = 0;
Page_numb = 2;
lcd_putsf("Change PhoneNum");
else
lcd_clear();
lcd_putsf("wrong Pass");
delay_ms(500);
lcd_clear();
pass_length = 0;
Page_numb = 1;
}که خطای زیر رو اعلام می کنه
Error: function argument #1 of type 'unsigned char' is incompatible with required parameter of type 'flash unsigned char *'
باتشکر
unsigned char b;
case 0 :
Page_numb = 1;
lcd_clear();
Page_numb = 1;
break;
case 1 :
lcd_clear();
pass[0] = key1;
pass_length = 1;
// lcd_puts(key1);
pass[1] = key1;
pass_length = 2;
//lcd_puts(key1);
pass[2] = key1;
pass_length = 3;
//lcd_puts(key1);
pass[3] = key1;
pass_length = 4;
lcd_clear();
delay_ms(500);
lcd_clear();
pass_length = 0;
Page_numb = 2;
else
lcd_clear();
delay_ms(500);
lcd_clear();
pass_length = 0;
Page_numb = 1;
باتشکر
