میخواستم با بسکام دو عدد را یکی برای تایمم و دیگری برای تاخیر پر کنم عدد اول مشکلی پیش نمی اید اما وقتی عدد دوم را میخوام بگیرم نمیشه برنامم رو چطور بنویسم>؟
$regfile = "m16def.dat"
$crystal = 8000000
Config Kbd = Portb , Delay = 200 , Debounce = 100
Config Portd = Output
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7 , E = Portc.7 , Rs = Portc.6
Dim A As Byte
Dim B As Byte
Dim C As Byte
Dim D As Byte
Dim E As Byte
Dim T As Byte
Dim R As Byte
Dim Count As Word
Dim Second As Byte
Main:
Cls
Locate 1 , 6
Lcd "Time :"
Do
A = Getkbd()
A = Lookup(a , Key)
Select Case A
Case Is < 10:
B = B * 10
B = B + A
Locate 2 , 7 : Lcd B ; " "
Case 15:
Goto Del
Case 13:
B = B / 10
End Select
Loop
Del:
Cls
Locate 1 , 6
Lcd "delay :"
Do
C = Getkbd()
C = Lookup(c , Key)
Select Case C
Case Is < 10:
D = D * 10
D = D + C
Case 15:
Goto Motor
Case 13:
D = D / 10
End Select
Loop
$crystal = 8000000
Config Lcd = 16 * 2
Dim A As Byte
Dim B As Byte
Dim C As Byte
Dim D As Byte
Dim E As Byte
Dim T As Byte
Dim R As Byte
Dim Count As Word
Dim Second As Byte
Main:
Cls
Locate 1 , 6
Lcd "Time :"
Do
A = Getkbd()
A = Lookup(a , Key)
Select Case A
Case Is < 10:
B = B * 10
B = B + A
Case 15:
Goto Del
Case 13:
B = B / 10
End Select
Loop
Del:
Cls
Locate 1 , 6
Lcd "delay :"
Do
C = Getkbd()
C = Lookup(c , Key)
Select Case C
Case Is < 10:
D = D * 10
D = D + C
Case 15:
Goto Motor
Case 13:
D = D / 10
End Select
Loop
