دوستان با تجربه ممکنه در مورد کاربرد signature bytes توضیح بدن ؟
NVM_PROD_SIGNATURES_RCOSC2M_offset = &H00 ' RCOSC 2MHz Calibration Value
NVM_PROD_SIGNATURES_RCOSC32K_offset =&H02 ' RCOSC 32kHz Calibration Value
NVM_PROD_SIGNATURES_RCOSC32M_offset = &H03 ' RCOSC 32MHz Calibration Value
NVM_PROD_SIGNATURES_LOTNUM0_offset = &H08 ' Lot Number Byte 0, ASCII
NVM_PROD_SIGNATURES_LOTNUM1_offset = &H09 ' Lot Number Byte 1, ASCII
NVM_PROD_SIGNATURES_LOTNUM2_offset = &H0A ' Lot Number Byte 2, ASCII
NVM_PROD_SIGNATURES_LOTNUM3_offset = &H0B ' Lot Number Byte 3, ASCII
NVM_PROD_SIGNATURES_LOTNUM4_offset = &H0C ' Lot Number Byte 4, ASCII
NVM_PROD_SIGNATURES_LOTNUM5_offset = &H0D ' Lot Number Byte 5, ASCII
NVM_PROD_SIGNATURES_WAFNUM_offset = &H10 ' Wafer Number
NVM_PROD_SIGNATURES_COORDX0_offset = &H12 ' Wafer Coordinate X Byte 0
NVM_PROD_SIGNATURES_COORDX1_offset = &H13 ' Wafer Coordinate X Byte 1
NVM_PROD_SIGNATURES_COORDY0_offset = &H14 ' Wafer Coordinate Y Byte 0
NVM_PROD_SIGNATURES_COORDY1_offset = &H15 ' Wafer Coordinate Y Byte 1
NVM_PROD_SIGNATURES_ADCACAL0_offset = &H20 ' ADCA Calibration Byte 0
NVM_PROD_SIGNATURES_ADCACAL1_offset = &H21 ' ADCA Calibration Byte 1
NVM_PROD_SIGNATURES_ADCBCAL0_offset = &H24 ' ADCB Calibration Byte 0
NVM_PROD_SIGNATURES_ADCBCAL1_offset = &H25 ' ADCB Calibration Byte 1
NVM_PROD_SIGNATURES_TEMPSENSE0_offset = &H2E ' Temperature Sensor Calibration Byte 0
NVM_PROD_SIGNATURES_TEMPSENSE1_offset = &H2F ' Temperature Sensor Calibration Byte 0
NVM_PROD_SIGNATURES_DACAOFFCAL_offset = &H30 ' DACA Calibration Byte 0
NVM_PROD_SIGNATURES_DACACAINCAL_offset = &H31 ' DACA Calibration Byte 1
NVM_PROD_SIGNATURES_DACBOFFCAL_offset = &H32 ' DACB Calibration Byte 0
NVM_PROD_SIGNATURES_DACBGAINCAL_offset = &H33 ' DACB Calibration Byte 1
