پاسخ : اینتراپت ساده در PIC18F
آقا یه سوال دیگه من برای کریستال که فرمودید #pragma config OSC=HS مینویسم این خطا رو میده
با میکروی PIC18F26K22 کار میکنم
و اون که مال واچداگ بودو به این تغییر دادم وگرنه اونم خطا میداد #pragma config WDTEN=OFF
[left]make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf make[1]: Entering directory `D:/PIC Projects/Interrupt26K22.X' make -f nbproject/Makefile-default.mk dist/default/production/Interrupt26K22.X.production.hex make[2]: Entering directory `D:/PIC Projects/Interrupt26K22.X' "D:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p18F26K22 -I "D:\Program Files (x86)\Microchip\mplabc18\v3.43\bin"\\..\\h -fo build/default/production/Interrupt26K22.o Interrupt26K22.c MPLAB C18 v3.43 (evaluation) make[2]: *** [build/default/production/Interrupt26K22.o] Error 3 Copyright 2000-2011 Microchip Technology Inc. make[1]: *** [.build-conf] Error 2 make: *** [.build-impl] Error 2 Days remaining until evaluation becomes feature limited: 49 WARNING: The procedural abstraction optimization will not be supported when the evaluation becomes feature limited. D:\PIC Projects\Interrupt26K22.X\Interrupt26K22.c:6:Error [1224] configuration setting 'OSC' not recognized make[2]: Leaving directory `D:/PIC Projects/Interrupt26K22.X' make[1]: Leaving directory `D:/PIC Projects/Interrupt26K22.X' BUILD FAILED (exit value 2, total time: 200ms) [/left]
