سلام کسی کتابخونه ds1307 رو داره ؟
ds1307
پاسخ : ds1307
کد:// Software I2C connections sbit Soft_I2C_Scl at RD7_bit; sbit Soft_I2C_Sda at RD6_bit; sbit Soft_I2C_Scl_Direction at TRISD7_bit; sbit Soft_I2C_Sda_Direction at TRISD6_bit; //End Software I2C connections unsigned char read_ds1307(unsigned char address ); void write_ds1307(unsigned char address,unsigned char w_data); unsigned char read_ds1307(unsigned char address) { soft_I2C_Start(); Soft_I2C_Write(0xd0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0 Soft_I2C_Write(address); soft_I2C_Stop(); soft_I2C_Start(); //soft_I2C_Repeated_Start(); Soft_I2C_Write(0xd1); //0x68 followed by 1 --> 0xD1 data1=soft_I2C_Read(0); soft_I2C_Stop(); return(data1); } void write_ds1307(unsigned char address,unsigned char w_data) { soft_I2C_Start(); // issue I2C start signal //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0 Soft_I2C_Write(0xD0); // send byte via I2C (device address + W) Soft_I2C_Write(address); // send byte (address of DS1307 location) Soft_I2C_Write(w_data); // send data (data to be written) soft_I2C_Stop(); // issue I2C stop signal } Vvoid main() { Soft_I2C_Init(); while() { sec=read_ds1307(0); // read second minute=read_ds1307(1); // read minute hour1=convert(hour); day=read_ds1307(4); year=read_ds1307(6); month=read_ds1307(5); } }
اگر سوالی داشتی من در خدمتم
