با سلام خدمت همگی دوستان
من میخوام که ماژول nrf24l01 رو راه اندازی کنم اما با مشکل مواجه شدم. برنامه رو میزارم تا دوستانیکه تجربه ای در راه اندازی این ماژول دارند بنده رو راهنمایی کنند. با mikroC کار میکنم.
برنامه transmitter :
#define ADR_LENGTH 5 // 5 bytes TX(RX) address width
#define TX_PLOAD_WIDTH 32 // 16 bytes TX payload
#define RX_PLOAD_WIDTH 32 // 16 bytes RX payload
// Define nRF24L01 interrupt flag's
#define IDLE 0x00 // Idle, no interrupt pending
#define MAX_RT 0x10 // Max #of TX retrans interrupt
#define TX_DS 0x20 // TX data sent interrupt
#define RX_DR 0x40 // RX data received
// SPI(nRF24L01) commands
#define READ_REG 0x00 // Define read command to register
#define WRITE_REG 0x20 // Define write command to register
#define RD_RX_PLOAD 0x61 // Define RX payload register address
#define WR_TX_PLOAD 0xA0 // Define TX payload register address
#define FLUSH_TX 0xE1 // Define flush TX register command
#define FLUSH_RX 0xE2 // Define flush RX register command
#define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
#define NOP 0xFF // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG 0x00 // 'Config' register address
#define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
#define SETUP_AW 0x03 // 'Setup address width' register address
#define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
#define RF_CH 0x05 // 'RF channel' register address
#define RF_SETUP 0x06 // 'RF setup' register address
#define STATUS 0x07 // 'Status' register address
#define OBSERVE_TX 0x08 // 'Observe TX' register address
#define CD 0x09 // 'Carrier Detect' register address
#define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
#define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
#define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
#define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
#define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
#define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
#define TX_ADDR 0x10 // 'TX address' register address
#define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
#define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
#define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
#define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
#define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
#define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
// Definitions used in TEST application
#define FALSE 0x00 // Simple true/false constants
#define TRUE 0x01
#define CLEAR 0x00
#define FREQ_TABLE_SIZE 0x10
#define TX_PLOAD_MAX_WIDTH 0x20
#define RX_PLOAD_MAX_WIDTH 0x20 // RX payload length = 32 bytes
#define NUM_OF_PIPES 0x06
#define TX_ADDR_WIDTH 0x05
#define TRANS_PARAMS 0x02
#define TRANS_SOURCE 0x00
#define TRANS_VALUE 0x01
#define TIMER 0x00
#define BUTTON 0x01
#define TX_MODE 0x00
#define RX_MODE 0x01
#define IDLE_MODE 0x02
#define MASK_IRQ_FLAGS 0x70
#define MASK_RX_DR_FLAG 0x40
#define MASK_TX_DS_FLAG 0x20
#define MASK_MAX_RT_FLAG 0x10
#define RX_P_NO 0x0e
#define RX_FIFO_EMPTY 0x07
#define RX_EMPTY 0x01
#define PIPE0 0x00
#define PIPE1 0x01
#define PIPE2 0x02
#define PIPE3 0x03
#define PIPE4 0x04
#define PIPE5 0x05
#define LINK_STATUS 0x00
#define LINK_CHANNEL 0x01
#define LINK_NO_MESS 0x00
#define LINK_LOSS 0x01
#define LINK_ESTABLISH 0x02
#define LINK_RELOST 0x03
#define STOP 0x04
#define CLEARED 0x00
#define TIMEOUT 0x01
// Implemented HOST commands
#define CSN_STATE 0x01 // Set state of CSN(SSN) signal
#define SPI_COMMAND 0x02 // Perform a SPI read/write operation
#define CE_BIT 0x03 // Set state of CE signal
#define FW_VER 0x04 // Returns FirmWare version of this system
#define READ_USB_ID 0x05 // Returns the rotary switch value
#define WRITE_LEDS 0x06 // Turn LEDs on/off
#define WR_FLASH_BLOCK 0x07 // Writes 32 bytes of flash data to block 'n'
#define RD_FLASH_BLOCK 0x08 // Reads and return 32 bytes of flash block 'n'
#define WR_FLASH_PAGE 0x09 // Writes the flash page n*256 buffer to flash
#define RD_FLASH_PAGE 0x0a // Read the n*256 flash page to flash buffer
#define WD_RESET 0x0b // Perform a WD reset
#define READ_LOCK_BYTE 0x0c // Returns the F32x device lock byte...
#define SPI_SELECT 0x0d // Select between HW and SW SPI mode
#define UNUSED 0x0e // Not used command
#define ST_FR_SWEEP_TX 0x0f // Start freq.sweep, TX, from channel 'cl' to 'ch' in 20ms intervals
#define ST_FR_SWEEP_RX 0x10 // Start freq.sweep, RX, from channel 'cl' to 'ch' in 20ms intervals
#define STOP_SWEEP 0x11 // Stop either the TX or the RX freq.sweep execution....
#define WR_TRANS_CTRL 0x12 // Select between auto. or manual transmission(TX device)
#define RD_TRANS_CTRL 0x13 // Read Transmit Control state
#define WR_FREQ_AGIL 0x14 // Select Freq. Agility for pipe.n
#define RD_FREQ_AGIL 0x15 // Read freq agility state for pipe.n
#define WR_CH_TABLE 0x16 // Writes the 16 ch's used for freq. agility
#define RD_CH_TABLE 0x17 // Read the 16 ch's used for agility
#define WR_TX_PAYLOAD 0x18 // Writes n bytes of payload data
#define START_COM_MODE 0x19 // Starts the communication mode, (application)
#define READ_TEMP 0x1a // Returns F320 temperature
#define READ_VOLT 0x1b // Returns RF_VDD voltage
#define ENTER_TEST_MODE 0x1c // Ev.board enters production test
#define READ_RX_DATA 0x1d // Host read RX data on pipe.n
#define READ_TX_PLOAD 0x1e // Host read current RX payload
#define WR_RX_PLOAD_LENGTH 0x1f // Host write current RX payload length for pipe.n
#define RD_RX_PLOAD_LENGTH 0x20 // Host read current RX payload length for pipe.n
#define WR_FREQ_AGILITY 0x21 // Command to enable/disable frequency agility
#define RD_FREQ_AGILITY 0x22 // Read previous command's parameter
#define UPDATE_DEVICE 0x23 // This command is sent before the nRF24L01 are beeing updated
#define STOP_COMM_MODE 0x24 // This sommand is sent when "Stop Communication Mode" button is pressed
#define RD_COMM_MODE_STAT 0x25 // Host read current communication mode status (0:TX, 1:RX, 2: IDLE)
#define RD_LINK_STATUS 0x26 // Host read current link status, i.e. message to host, RX device side
#define CE LATC.B2
#define CSN LATA.B3
// Predefine a static pipe address
unsigned char ADDRESS_P0[ADR_LENGTH] = {0x34,0x43,0x10,0x10,0x01};
unsigned char ADDRESS_P1[ADR_LENGTH] = {0xB3,0xB4,0xB5,0xB6,0x02};
unsigned char ADDRESS_P2[ADR_LENGTH] = {0xB3,0xB4,0xB5,0xB6,0x03};
unsigned char ADDRESS_P3[ADR_LENGTH] = {0xB3,0xB4,0xB5,0xB6,0x04};
unsigned char ADDRESS_P4[ADR_LENGTH] = {0xB3,0xB4,0xB5,0xB6,0x05};
unsigned char ADDRESS_P5[ADR_LENGTH] = {0xB3,0xB4,0xB5,0xB6,0x06};
static unsigned int second=0 ;
char txt1[6]="salam";
/////////global functions
void TX_MODE_NRF(void);
unsigned char L01_Clear_IRQ(unsigned char irq_flag);
unsigned char nRF_SPI_RW(unsigned char byte);
unsigned char nRF_SPI_Read(unsigned char reg);
unsigned char nRF_SPI_RW_Reg(unsigned char reg, unsigned char value);
unsigned char nRF_SPI_Write_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes);
unsigned char nRF_SPI_Read_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes);
void main(void){
PORTA=0x00;
PORTB=0x00;
PORTC=0x00;
TRISA=0xbf;
TRISB=0x19;
TRISC=0x13;
LATA=0x00;
LATB=0x00;
LATC=0x00;
CE=0;
CSN=1;
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV16, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
delay_ms(1000);
TX_MODE_NRF();
while(1){
nRF_SPI_Write_Buf(WR_TX_PLOAD, &txt1 , 5 );
delay_ms(500);
* Function: TX_Mode
* Description:
* This function initializes one nRF24L01 device to TX mode, set TX address,
* set RX address for auto.ack, fill TX payload, select RF channel, datarate & TX pwr.
* PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX.
* ToDo: One high pulse(>10µs) on CE will now send this
* packet and expext an acknowledgment from the RX device.
* In/Out parameters:
* In: none
* Out: none
CE=0; // Set CE pin low to enable stanby mode
nRF_SPI_RW_Reg(FLUSH_TX,0);
nRF_SPI_RW_Reg(FLUSH_RX,0);
L01_Clear_IRQ(MASK_IRQ_FLAGS); // Clear interrupts
nRF_SPI_RW_Reg(WRITE_REG + EN_AA, 0x3f); // Enable Auto.Ack:Pipes 0-5
nRF_SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x3f); // Enable Pipes 0-5
nRF_SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500µs + 86µs, 10 retrans...
nRF_SPI_RW_Reg(WRITE_REG + RF_CH, 40); // Select RF channel 40
nRF_SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x0f); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
nRF_SPI_RW_Reg(WRITE_REG + CONFIG, 0x7e); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:TX. MAX_RT & TX_DS enabled..
nRF_SPI_Write_Buf(WRITE_REG + TX_ADDR, &ADDRESS_P0, sizeof(ADDRESS_P0)); // Writes TX_Address to nRF24L01
nRF_SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, &ADDRESS_P0, sizeof(ADDRESS_P0)); // RX_Addr0 same as TX_Adr for Auto.Ack
Delay_ms(200);
// This device is now ready to transmit one packet of 16 bytes payload to a RX device at address
// '3443101001', with auto acknowledgment, retransmit count of 10(retransmit delay of 500µs+86µs)
// RF channel 40, datarate = 2Mbps with TX power = 0dBm.
// Function: nRF_SPI_Write_Buf
// Description:
// Writes contents of buffer '*pBuf' to nRF24L01
// Typically used to write TX payload, Rx/Tx address
// In/Out parameters:
// In: register 'reg' to write, buffer '*pBuf*' contains
// data to be written and buffer size 'buf_size' is #of
// bytes to be written
// Out: return nRF24L01 status byte.
unsigned char status, byte_ctr;
CSN = 0; // Set CSN low, init SPI tranaction
status = nRF_SPI_RW(reg); // Select register to write to and read status byte
for(byte_ctr=0; byte_ctr<bytes; byte_ctr++) // then write all byte in buffer(*pBuf)
nRF_SPI_RW(*pBuf++);
CSN = 1; // Set CSN high again
return(status); // return nRF24L01 status byte
// Function: nRF_SPI_Read_Buf
// Description:
// Reads 'bytes' #of bytes from register 'reg'
// Typically used to read RX payload, Rx/Tx address
// In: 'reg', register to read from, '*pBuf' are buffer
// the read bytes are stored to and 'bytes' are #of bytes
// to read.
for(byte_ctr=0;byte_ctr<bytes;byte_ctr++) // Perform SPI_RW to read byte from nRF24L01
pBuf[byte_ctr] = nRF_SPI_RW(0);
* Function: L01_Clear_IRQ
* Description:
* Clear nRF24L01 IRQ flag(s).
* In: IRQ Flag
* Out: Reg state
return nRF_SPI_RW_Reg(WRITE_REG + STATUS, irq_flag);
* Function: nRF_SPI_RW
* Description:
* Writes one byte to nRF24L01, and return the byte read
* from nRF24L01 during write, according to SPI protocol
* In: 'byte', current byte to be written
* Out: 'SPI2'
return(SPI1_Read(byte)); // Perform HW SPI operation
// Description:
// Read one byte from nRF24L01 register, 'reg'
// In: reg, register to read
// Out: return reg_val, register value.
unsigned char reg_val;
CSN = 0; // CSN low, initialize SPI communication...
nRF_SPI_RW(reg); // Select register to read from..
reg_val = nRF_SPI_RW(0); // ..then read registervalue
CSN = 1; // CSN high, terminate SPI communication
return(reg_val); // return register value
// Function: nRF_SPI_RW_Reg
// Description:
// Writes value 'value' to register 'reg'
// In: 'reg' register to write value 'value' to.
// Return status byte.
unsigned char status;
CSN = 0; // CSN low, init SPI transaction
status = nRF_SPI_RW(reg); // select register
nRF_SPI_RW(value); // ..and write value to it..
CSN = 1; // CSN high again
