ds1307
پاسخ : ds1307
با سلامنوشته اصلی توسط arvinfxکسی با بیسکشو داره این با Cآهستش انگار هیج جای دنیا این ای سی رو با بیسیک راه ننداختن برای PIC :angry:
با مقداری جستجو در اینترنت ، بدست می آید
http://itp.nyu.edu/~raf275/blog/archives/2006/12/xbee_time_broad.html
یک برنامه برای ds1307 با picbasic
======================================' PICBASIC PRO LCD clock program using Dallas DS1307 I2C RTC
' Define LOADER_USED to allow use of the boot loader.
' This will not affect normal program operation.
Define LOADER_USED 1
' RESET_ORG can be set to move the BASIC program out of the way
' of any boot loader running from location 0, such as the
' Microchip USB boot loader
'Define RESET_ORG 800h
Define OSC 48 ' Core is running at 48MHz
Define LCD_DREG PORTD ' Define LCD connections
Define LCD_DBIT 4
Define LCD_RSREG PORTE
Define LCD_RSBIT 0
Define LCD_EREG PORTE
Define LCD_EBIT 1
' Alias pins
SDA Var PORTA.4
SCL Var PORTA.5
' Allocate variables
RTCYear Var Byte
RTCMonth Var Byte
RTCDate Var Byte
RTCDay Var Byte
RTCHour Var Byte
RTCMin Var Byte
RTCSec Var Byte
RTCCtrl Var Byte
ADCON1 = 15 ' PORTA and E digital
Low PORTE.2 ' LCD R/W low = write
Pause 100 ' Wait for LCD to startup
' Set initial time to 8:00:00AM 06/21/05
RTCYear = $05
RTCMonth = $06
RTCDate = $21
RTCDay = $02
RTCHour = $08
RTCMin = 0
RTCSec = 0
RTCCtrl = 0
Gosub settime ' Set the time
Goto mainloop ' Skip over subroutines
' Subroutine to write time to RTC
settime:
I2CWrite SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
Return
' Subroutine to read time from RTC
gettime:
I2CRead SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
Return
' Main program loop - in this case, it only updates the LCD with the time
mainloop:
Gosub gettime ' Read the time from the RTC
' Display time on LCD
Lcdout $fe, 1, hex2 RTCMonth, "/", hex2 RTCDate, "/" , hex2 RTCYear,_
" ", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec
Pause 500 ' Do it about 2 times a second
Goto mainloop ' Do it forever
End
منبع :
http://picbasic.com/resources/samples.htm
و یک برنامه دیگر :
http://microengineeringlabs.com/resources/samples/submitted/MN1307.txt
