برنامه ای از اینترنت مربوط به میکروکنترلر pic دانلود کرده ام اما در تشخیص زبان برنامه نویسی ان مشکل دارم. لطفا دوستان بازبینی فرمایند و اسم نرم افزار و زبان برنامه نویسی را ذکر نمایند.
برنامه:
برنامه:
list F=inhx8m, P=12F615, R=hex, N=0
#include P12F615.inc; PIC definitions
__config _BOR_ON & _IOSCFS_8MHZ & _CP_OFF & _MCLRE_ON & _PWRTE_OFF & _WDT_OFF & _INTOSCIO
Errorlevel -302, -224 ; switches off Message [302]: Register in operand not in bank 0.
; Definitions -------------------------------------------------------------
#define OutputPin porta,0
#define ToggleSelect porta,5
#define SensitivitySelect porta,4
#define PreviousButtonState Flags,0
; RAM preserved -----------------------------------------------------------
cblock 0x40
WaitCounter,WaitCounter2
PassArg1,PassArg2
PassArg3,PassArg4
Press_Threshold_H,Press_Threshold_L
Release_Threshold_H,Release_Threshold_L
Flags
endc
; Conastants --------------------------------------------------------------
GLPressHysteresis_H = b'00000001' ;High sensitivity
GLPressHysteresis_L = b'00000010' ;High sensitivity
GLReleaseHysteresis_H = b'00000001' ;High sensitivity
GLReleaseHysteresis_L = b'00000000' ;High sensitivity
GLPressHysteresis_H_2 = b'00000001' ;Low sensitivity
GLPressHysteresis_L_2 = b'00001110' ;Low sensitivity
GLReleaseHysteresis_H_2 = b'00000001' ;Low sensitivity
GLReleaseHysteresis_L_2 = b'00001000' ;Low sensitivity
; Program Memory ----------------------------------------------------------
org 0
goto Init
; Interrupt Service Routine -----------------------------------------------
org 4 ; ISR beginning
; Microcontroller initialization
Init
include myInitilization.inc ;Include the PIC Initialization routine
; Main Program ------------------------------------------------------------
Start
;TRIS setup
bank1 ;Go to bank 1
movlw b'11111010' ;
movwf TRISA ;Set the port pin types of the RA
bank0 ;Go to bank 0
bcf OutputPin
MOVLW b'11100111'
option
bsf cmcon0,CMON ;Enable comparator
bcf cmcon0,CMPOL ;Logic is inverted
bcf cmcon0,COUT ;
bsf cmcon0,CMOE ;Output to COUT pin
bsf cmcon0,CMR ;V+ driven to Vref
bcf cmcon0,CMCH ;V- driven to channel 0
bcf CMCON1,T1ACS ;Timer 1 Clock Source is Instruction Clock (FOSC\4)
bcf CMCON1,CMHYS ;Comparator Hysteresis disabled
bsf CMCON1,T1GSS ;Timer 1 Gate Source is T1G pin (pin should be configured as digital input)
bcf CMCON1,CMSYNC ;Output is asynchronous
movlw b'00010000'
movwf vrcon
;Set the press threshold
call wait250msec
call wait250msec
call wait250msec
call wait250msec ;Wait for frequency to become stable
call GetFrequencyCount
movlw GLPressHysteresis_H_2
btfsc SensitivitySelect
subwf passarg1,w ;Sub from count HIGH the HIGH byte of Press Thresshold
movwf Press_Threshold_H ;And save it to memory
movlw GLPressHysteresis_L_2
subwf passarg2,w ;Sub from count LOW the LOW byte of Press Thresshold
movwf Press_Threshold_L ;And save it to memory
;Set the release threshold
movlw GLReleaseHysteresis_H_2
subwf passarg1,w ;Sub from count HIGH the HIGH byte of Release Thresshold
movwf Release_Threshold_H ;And save it to memory
movlw GLReleaseHysteresis_L_2
subwf passarg2,w ;Sub from count LOW the LOW byte of Release Thresshold
movwf Release_Threshold_L ;And save it to memory
MainLoop
;Check if pressed
movf passarg2,w
movwf passarg4 ;Save Prescaller Count
movf passarg1,w
movwf passarg3 ;Save TMR0 Count
movf Press_Threshold_L,w
subwf passarg2,w ; R= Prescaller - LOW threshold
btfss carry
decf passarg1,f ;If R < 0, decrease passarg1 (TMR0 count)
movf Press_Threshold_H,w
subwf passarg1,w ; R= TMR0 - HIGH threshold
btfsc carry
goto IsNotPressed ;If R < 0, Button is NOT Pressed
;Else is pressed
btfss ToggleSelect ;If ToggleSelect is LOW (pushbutton action)
goto ActivateOutput ;Then just activate output
btfsc PreviousButtonState ;Else, check if previous state was RELEASED
goto PressReleaseCheckDone ;If not, then do nothing
;If WAS released...
bsf PreviousButtonState ;Update previous state
movlw b'00000001'
xorwf PORTA,f ;Toggle output
call wait100msec ;and wait 100msec
ActivateOutput
bsf OutputPin
IsNotPressed ;Check if released
movf passarg3,w
movwf passarg1 ;Restore TMR0 Count
movf Release_Threshold_L,w
btfss carry
decf passarg1,f ;If R < 0, decrease passarg3 (TMR0 count)
movf Release_Threshold_H,w
btfss carry
goto PressReleaseCheckDone ;If R > 0, Button is NOT Released
;Else is released
bcf OutputPin ;Then deactivate output
bcf PreviousButtonState ;else (Toggle) do not deactivate it
goto MainLoop
GetFrequencyCount
;This sub returns PassArg1:PassArg2 as the TMR0:Prescaller count
clrf passarg1
movlw d'44' ; Set the maximum prescaller value
movwf passarg2 ; to start decreasing (max 43+1)
clrf tmr0
call wait10msec
call wait10msec
call wait10msec
call wait10msec
call wait10msec
call wait10msec
movf tmr0,w
movwf passarg1
MOVLW b'11000111' ;Tmr0 source is Fosc/4
option
GetPrescallerValue
decF passarg2,f ;1
MOVF tmr0,w ;1
XORWF passarg1,w ;1
BTFSC status,z ;1
GOTO GetPrescallerValue ;2 = total 6 instruction cycles
;So, it prescaller is 0 (min), we can measure (ceil)255/6=43
MOVLW b'11100111' ;Tmr0 source is T0CKI
option
return
include mSecDelays8MHz.inc
Fins
end ; end of program
