با سلام کسایی که PIC بلد هستند این کد داره چی میگه؟ البته برنامش کامل نیست
[code=c]
const unsigned char SinLkUpTab[50]= {0, 8, 16, 24, 31, 39, 47, 55, 62, 70, 77, 85, 92, 99,
106, 113, 120, 127, 134, 141, 147, 153, 159, 165, 171, 177, 182, 188, 193, 198, 202, 207,
211, 215, 219, 223, 226, 229, 232, 235, 238, 240, 242, 244, 246, 247, 248, 249, 250, 250};
unsigned short cnt,inc,dec,sqinc,cnt1;
void interrupt()
if (dec==0)
{cnt++;
PWM1_Set_Duty(SinLkUpTab[cnt]);
else if (dec==1)
{cnt–;
TMR1IF_bit = 0; // clear TMR0IF
TMR1H = 0xFF; // Initialize Timer1 register
TMR1L = 0x76;
void main()
TRISB = 0; // designate PORTB pins as output
PORTC = 0; // set PORTC to 0
PORTB = 0; // set PORTC to 0
TRISC = 0; // designate PORTC pins as output
TRISA = 0; // designate PORTB pins as output
PORTA = 0; // set PORTC to 0
T1CON= 0b00000001; // Timer1 settings
TMR1IF_bit = 0; // clear TMR1IF
TMR1L = 0x76;
TMR1IE_bit = 1; // enable Timer1 interrupT
cnt = 0; // initialize cnt
[/code]
[code=c]
void interrupt()
if (dec==0)
{cnt++;
else if (dec==1)
{cnt–;
TMR1L = 0x76;
void main()
TMR1L = 0x76;
[/code]
