اگه کسی یه پروپ همه کاره احتیاج داره حتما اینو بسازه . از اهم متر بیشتر کاربرد داره (برای من که اینجور بود )
PCB اونو خودم کشیدم و بدون مشکل کار میده
Here are how each of the modes work at present....
این هم مداری که من درست کردم
لینک دانلود PCB
هگز فایل
فقط اون 4 تا ترانزیستور درایو سگمنت لحیم نکنید مستقیم اتصال کوتاه کنید . اون هارو اشتباه زدم
و من الله بای بای
| Prob | Logic Probe | The logic probe shows 'H' for high (over 3.7 volts), 'L' for low (below 0.8 volts) and '-' for floating in the first display location. If a pulse is detected (0.5 usec minimum), the second location flashes a 'P'. |
| PULS | Logic Pulser | The logic pulser shows the pulse rate (5, 50, 500, 5.0) in the last 3 locations. The first location shows the sensed logic level as a dash in the bottom or top of the digit. When button #1 is held down, a series of 0.5 microsecond pulses are generated in the opposite direction and the center segment is lit. Pushing button #2 cycles thru the 4 pulse rates. The selected pulse rate is saved on power down. |
| FrEq | Frequency Counter | In the frequency counter mode, hitting button #1 switches the display to the next 4 digits of the count. For instance, the display shows '12.57' for a frequency of 12,576 hz. Holding down button #1 shows '2576' - the lowest 4 digits. If a decimal point shows, the value is in Khz, if the decimal is flashing, the value is in Mhz. Hence, a frequency of 42,345,678 hz is displayed as 42.34 with a flashing decimal. Holding down button #1 in this case will display 5678. |
| Cnt | Event Counter | In the event count mode, the display shows the lowest 4 digits. Button #1 switches to the next higher 4 digits while held down. Button #2 resets the count. |
| VoLt | Voltmeter | The voltmeter uses the power going into the probe as a voltage reference. The current implementation shows only an approximate voltage - about 2% high. This can still be very useful for most measurements. Do not connect the probe to voltages that exceed 5 volts under any conditions. |
| diod | Diode Junction Voltage | This is just the voltmeter function with 10k resistor feeding current to the probe tip. When a diode or transistor junction is connected from the tip to the ground lead, the drop voltage is displayed. |
| Cap | Capacitance Measurement | When a capacitor is connected from the tip to the ground lead, and button #1 is pushed, its value is displayed. Values from .001 uf to about 500 uf are displayed. The larger the capacitor, the longer it takes to measure. A value of 100uf takes a couple of seconds. |
| Coil | Inductance Measurement | When an inductor is connected from the tip to the ground lead, and button #1 is pushed, its value is displayed. Values from 0.1 to 999.9 millihenries are displayed. Note: this function assumes that the DC resistance is not more than a few ohms. Also, if the unit gets 'stuck' in this mode, jumper the tip to ground to free it. |
| SIG | Signal Generator | This mode generates a 500hz square wave at about 0.5 volts. The signal is only generated while button #1 is held down. |
| ntSC | Video Pattern | Generates an NTSC video frame with a white dot pattern. |
| 9600 | Serial Ascii | Each time button 1 is pushed, the letters A-Z followed by cr/lf is generated. Auto polarity sensing. If the signal injection point is originally high, then normal (zero start bit) ascii is generated. Otherwise, the other polarity is done. New feature: Button #2 cycles thru 1200, 2400, 4800, 9600 baud. |
| Midi | Midi Note | Sends note number 60 (middle C) on any of the 16 midi channels. Holding button 1 sends 'note on'. Release of button 1 sends 'note off'. Button 2 cycles thru the 16 channels. The midi channel number is stored. |
| R/C | R/C Servo | Generates 1ms to 2ms pulse for r/c servos. Button 1 increases pulse, Button 2 decreases pulse. Defaults to 1.5 ms each time mode is entered. |
| [ ] | Square Wave | Generates 1 - 9999 hz square wave. Button 1 decreases frequency, Button 2 increases frequency. |
| Prn | Pseudo Random Number | Generates 10khz digital PRN series. |
| ir38 | IR LED |
Generates 1 millisecond on and 2.5 millisecond off of 38khz square wave. When connected to IR LED, used for testing IR receiver modules. |
| PWM | Pulse Width Modulation |
Generates variable pulse width 3-97 percent of a 6khz (approx) digital signal. Button 1 decreases pulse width, Button 2 increases pulse width. |
| StOP | Stop Watch | Button 1 starts/stops timer. Change of state on probe tip also will start/stop timer. Button 2 resets timer. Timer counts in 1/100 seconds from 0-99 seconds, then counts in 1/10 seconds from 100-999 seconds, then counts in whole seconds from 1000-9999 seconds (about 2 hours 46 minutes). |
لینک دانلود PCB
هگز فایل
:02000000C62810 :10000800A000030EA10083012D0882075F29252A7D :10001800210E8300A00E200E090082073F3406340B :100028005B344F3466346D347D3407347F34673441 :100038008207013402340434083482070334033459 :10004800033403349434A534C634D734E834F9344B :100058008207013401348434843484349534A634DA :10006800B734C834D9348207AA3437341134053444 :100078002908A90A820764340534A83402344A34AA :100088000134A03400342908A90A82077334503493 :100098005C347C3473343E3438346D343E345C34F0 :1000A800383478345E3404345C345E34713450341B :1000B80079346F3400343934543478340034393472 :1000C8007734733439345C340434383400346D3460 :1000D80006343D34543478346D34393400346D3456 :1000E80079345034153404345E34043421345234B1 :1000F8005834003439340F340034003473345034F5 :1001080054340034043450344F347F3473342A3434 :10011800153400346D3478343F347334003400348B :1001280000346D34003400346D343F3400346D34A1 :100138003F343F3400340034ED343F3406345B340C :100148003F343F345B3466343F343F3466347F3465 :100158003F343F3467347D343F343F3436088207B8 :10016800262B6A2A762B732B302CFA2BCB2AFD2AC6 :100178009C2AB62CDA2D122EE329332AC429A02969 :100188006C29A22B83163F30850000308600B030E2 :10019800870088308100831204309200D001501407 :1001A800CC0122214C21E830B3000330B4003030B8 :1001B800B50014218B1336083F2148250A30A524A1 :1001C800071AF428871EE12848250A30A524071AAB :1001D8000129871AE828B6031130B61BB600DE28B5 :1001E80048250A30A524871A0129071AF428B60ACF :1001F8003608123A0319B601DE2814210421B22860 :100208008316051485140516051587170717851510 :10021800851606309F0083120800231D080023114D :10022800BB01BC013608C425BC0A3A08C425BC0A6F :100238003908C425BC0A3808C4250800BB01BC011C :10024800B625B6003608EE3E0318B601BC0AB62538 :10025800BA003A08FC3E0318BA01BC0AB625B90030 :10026800F13E0318B901BC0AB625B8003808FC3EAF :100278000318B8010800A9000310A90DA90D47200B :10028800C8004720C9004720CA004720CB00080003 :1002980026306C230030C800CA175821582158212D :1002A80036083F2158210800A40148250C30A52410 :1002B800A40B592908000B11231E672923120510C6 :1002C8002C0881000C28231605142B0881000C2803 :1002D800831605108230810083120030AD008B1622 :1002E8008B173508023E6C233508003CAB003508F7 :1002F800603C003CAC000A30A52448250A30A524FF :100308004825B00B7F291930B0000530A5244825B1 :10031800071E9229871E9829B0018929871EDE2881 :10032800B50BB503B50A7529071EDE28B50A3508C9 :10033800603A0319B5037529831605108312B12194 :100348000530A40048250930A524A40BA62921239B :10035800071AA329871AA329DE282630A400051422 :100368001430D100D10BB6290000000000000510A0 :100378001430D100D10BBE290000A40BB32908000A :100388008316051083125530BD00D8213D18051479 :100398003D1C051048254130D100D10BD129871AC1 :1003A800C929071AC929DE283D083E07BE003F07AC :1003B800BF000310BD0C0318BD17BD070800831646 :1003C80005108312DC30B0000530B1003008C000E1 :1003D8003108C100C201C301952565253230A4004A :1003E80048250A30A524A40BF4293008BC0031089C :1003F800BB0021231A22071E0F2A871E042AF2296E :10040800071EDE280A30B0070318B10A3108093A76 :100418000319112AEA29871EDE28F630B007031CC3 :10042800B1033108023A0319062AEA29BB0ABC0AB1 :10043800051400000000BC0B1D2ABB0B1F2A051069 :1004480008000B113308B00734080318340FB1073C :10045800B11F0510B11B0514B73081070C2883168E :1004680005108830810083120130AD008B178B1680 :100478003308C0003408C100C201C30195256525B1 :100488003708A40048250A30A524A40B462AFB30C7 :10049800B7073708FB3E0318532A0630B700071E74 :1004A8005F2A871E592AB701442A071EDE28B30A85 :1004B8000319B40A3C2A871EDE28FF30B307031C41 :1004C800B403B41F3C2AB301B4013C2A8316063096 :1004D8009F0083123A08123E3F213A083720B000A5 :1004E8007C2A831605100000051483124817832AF6 :1004F8000514051A0510083005180130C800300821 :100508009B2402309B24071A8C2A871A752ADD2817 :10051800871A7C2A0A30A52467234825071EDD2868 :10052800871E8E2ABA0A3A08033C031CBA016E2AAF :1005380083168713851106309F0083128713851150 :10054800C80105301120C90000301120CA00CB00B5 :10055800301F48178515BA22B00A301B4813851179 :10056800BA22071AB02A871AAC2ADE282030A4003B :1005780048250E30C222A40BBC2A0800D100000076 :100588000000000000000000D10BC32A08008316F9 :10059800851183128515051023142123C001C1017B :1005A800C201C30183160514831200000000000075 :1005B8000000000000000000000000000000000033 :1005C80000000000000000000518F22AC00FDF2A12 :1005D800C10FDF2AC20FDF2AC30FDF2A83160510D7 :1005E80083129525AF245723071AF72A871AD12A89 :1005F800DE2883168510831285102314212350309A :10060800A524C001C101C201C30185140000051C55 :10061800162BC00AC00F0A2BC10F0A2BC20F0A2BB8 :10062800C30F0A2B8510952503306325CA17572356 :10063800071A1B2B871A022BDE28071087100711B1 :1006480087110800831687130713A83081000E301E :100658009F0083128717071381309F00CD01FF3059 :100668008100071A3A2B871A3A2BDE2896233B0873 :10067800283C0318472B3B08B43C031C452B40304F :10068800482B7630482B383065230B1D512B0B1126 :10069800FF308100B0017330C9005923B00AB00897 :1006A8000319C901352BA4015E2BA401A4175E2BE5 :1006B800A4012417482565240A30A524A40B5E2B21 :1006C8000800C800682BC801C901CA01CB0108008D :1006D800C000C101C201C301952565250800831624 :1006E8008713772B83168E309F00831287178130EC :1006F8009F0096230310BB0CBC0C3C08C0003B08B1 :10070800C100C201C30195256525C917C830A400D9 :1007180048250A30A524A40B8C2B071A7D2B871A91 :100728007D2BDE281F15000000001F19992B83164A :100738001E088312BC001E08BB000800831687131E :1007480083128713013090004525F523E223DB232C :10075800E623DB23031DBF2B071AB52B871AB82BFB :10076800DE28871AAC2BA82BC923C923C923C92380 :10077800C923071EBC2BC923DB23031DC52B071A5E :10078800BF2BE623871AC52BA82BE6230C1CC92BE5 :1007980045250C10B0308E003C308F00E223E92351 :1007A8005E08FC3E031CC9170319CA170800600835 :1007B800A9000508E0002906013908002724952525 :1007C8006525080048250530A52CC40A031D080026 :1007D800C50A031D0800C60A031D0800C70A031D31 :1007E8000800C401C501C601C701080083168516A3 :1007F8008713051585150514A830810006309F005C :10080800831287178101C401C501C601C7012724C6 :1008180095250330632548251C24071E162C871EA2 :10082800062C0B2C871EDE282724952507300E2C36 :100838000108C4000B1D08000B11C50F0800C60FE6 :100848000800C70A08004408C0004508C100460857 :10085800C2004708C30008008316851687170515C8 :1008680085110514A730810006309F0083120511F9 :10087800C001C101C201C30195256525071A482C8D :10088800871EDE28033063254C2475245624402C0B :1008980085128101C001C101C201C30183168516F9 :1008A8008312080085128316851283120108C1007D :1008B800C001C003851685120108410603195D2C85 :1008C80008004D0E0339483E8400CD1B8017CE0A20 :1008D8000319CF0ACF1E732C4D1B8013080000008C :1008E8000800EE30B000A730B100000000008924F5 :1008F800482565249024B00B792CB10B7B2C08304B :10090800B0009024B00B852C08001030A900A90B6A :100918008B2C0000000008000B1D972C0B11C20A3D :100928000319C30A08000000000000000800D200F4 :10093800D3005308D1004825D10B9F2CD20B9D2CF6 :100948000800D300D200D100D10BA82CD20BA72CC1 :10095800D30BA62C0800792524082C20CD000F39AC :10096800A4006B2D83160511851085108312851040 :1009780007118711BF308600E3242830A400000047 :100988000A25A40BC32C0F30A40013251225122509 :1009980009250925092509250925092509250925DF :1009A800092509250000A40BC92C1130A4000A252B :1009B8000000A40BDB2CFF24871AC02CDE2806308D :1009C800A4000511312505152E303825A40BE52C7A :1009D8000630A40005112E30382505153325A40B43 :1009E800EE2C0630A4000511312505152E303825CA :1009F800A40BF72C0800372505112B2534250515E0 :100A08003C255930382500000800372505112B25CD :100A1800342505155D3038250000080037250511F7 :100A28002B2534250515292529251330A900000073 :100A38000000000000000000000085140000851080 :100A4800A90B1B2D05303825080000000000000008 :100A5800000000000000000000000000000000008E :100A68000000000000000800A900A90B392D0800AB :100A7800DD0A071087105D1C07145D188714000035 :100A88000800F03087050800F03087054C08483E1C :100A9800840000085005FF3A86004C081C20870493 :100AA8000310D00D03185E2D0000000000000000A8 :100AB800000008005014CC0A4C19CC010800A4000E :100AC8006B2D792524082120CD000F39A400742529 :100AD800C8007425C9007425CA007425CB00080015 :100AE8002408A4038425112008000930A400240840 :100AF800DE008425003A031D0800A40B7B2D0800A6 :100B0800A9000301A91B08000310A90C2908A90DB5 :100B1800543E84000008A7002918A70E27080F399B :100B280008002030DC00D401D501D601D701D80156 :100B3800543084000530DB00333080078019F039E9 :100B4800801B0F398002840ADB0BA02DC00DC10D5C :100B5800C20DC30DD40DD50DD60DD70DD80DDC0B98 :100B68009C2D0800831203173C088D003B088F005A :100B780083168C130C1483120C08031383120800B9 :100B8800831203178C003C088D003B088F008316E6 :100B98008C130C1555308D00AA308D008C14000074 :100BA80000008C18D52D83120313080045258316E1 :100BB800051483123808A9000310A90D3C20AE00C3 :100BC8003C20AF00163038073F214825871E072EE6 :100BD800071AE92D871EDE2846264130A8001A305C :100BE800A50028084D26A80A2B309B24A50BF52D17 :100BF8000D304D2664309B240A304D26DC309B2472 :100C0800071EE92DDA2D45252830A524071EDE28E4 :100C1800871E072EB80A38112315DA2D3908013E28 :100C28006C233930C8007630C90083160514831246 :100C38004825871E3B2E071A1C2E46262D30AE004F :100C4800AF01390890384D263C304D2628304D26C6 :100C580014309B24071E2C2E390890384D263C3022 :100C68004D2600304D261121FA309B24122E643077 :100C78009B24071EDE28871E3B2E2315B90A0F303A :100C8800B905122EA310051CA31483160510831290 :100C98000800A401A415A7005F2669262718642662 :100CA800271C5F26A70CA40B512E692664266926EB :100CB800692669260800A31C0510A3180514080056 :100CC800A31C0514A318051008002F08AA002E0855 :100CD800A900AA0AA90AA90B6F2EAA0B6F2E080051 :02400E00323F3F :00000001FF
و من الله بای بای
