من میخوام code configurator رو تو محیط MPLAB نصب کنیم.بدین منظور به سایت میکروچیپ مراجعه کردم و فایل مربوطه را هم دانلود کردم(ورژن 3.25)
حالا تو MPLAB تو منوی tools و قسمت پلاگینز قسمتی وجود داره که میشه فایل دانلود شده را معرفی کرد و نصب کرد.رفتم و Add کردم و سپس دکمه install رو زدم
متاسفانه کدهای خطایی دریافت میکنم که اصلا نمیدونم چطور باید رفع بشن
خواهمشندم دوستان گرامی اگر میدونید راهنمایی کنید
کد های خطا
Some plugins require the Java platform in version Java > 1.8
The Java platform version Java > 1.8 was requested but only 1.7 is running. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Embedded Make Projects to be installed.
The plugin Embedded Make Projects is requested in version >= 1.2 but only 1.0 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin com.microchip.mplab.nbide.softwarenotification to be installed.
The plugin com.microchip.mplab.nbide.softwarenotification is requested in version 1.0. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin org.netbeans.libs.javafx to be installed.
The plugin org.netbeans.libs.javafx is requested in version 2.4.1. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Diff to be installed.
The plugin Diff is requested in version >= 1.47.1.42.1 but only 1.28.2.42.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Options Dialog and SPI to be installed.
The plugin Options Dialog and SPI is requested in version >= 1.41.1 but only 1.18.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Project API to be installed.
The plugin Project API is requested in version >= 1.60.2 but only 1.31.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Project UI API to be installed.
The plugin Project UI API is requested in version >= 1.78.1.8 but only 1.47.2.8 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Settings API to be installed.
The plugin Settings API is requested in version >= 1.45.1 but only 1.26.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin UI Utilities API to be installed.
The plugin UI Utilities API is requested in version >= 7.62.1 but only 7.23.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Dialogs API to be installed.
The plugin Dialogs API is requested in version >= 7.38.1 but only 7.15.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin File System API to be installed.
The plugin File System API is requested in version >= 8.12.1 but only 7.38.2 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin I/O APIs to be installed.
The plugin I/O APIs is requested in version >= 1.45.1 but only 1.23.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Datasystems API to be installed.
The plugin Datasystems API is requested in version >= 7.57.2 but only 7.16.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Module System API to be installed.
The plugin Module System API is requested in version >= 7.43.1 but only 7.17.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Nodes API to be installed.
The plugin Nodes API is requested in version >= 7.39.1 but only 7.16.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Text API to be installed.
The plugin Text API is requested in version >= 6.62.2 but only 6.30.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Utilities API to be installed.
The plugin Utilities API is requested in version >= 8.39.1 but only 8.6.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Lookup to be installed.
The plugin Lookup is requested in version >= 8.25.1 but only 8.3.1 was found. The following plugin is affected: MPLAB® Code Configurator
Some plugins require plugin Window System API to be installed.
The plugin Window System API is requested in version >= 6.71.1 but only 6.33.1 was found. The following plugin is affected: MPLAB® Code Configurator Some plugins not installed to avoid potential installation problems.
کد های خطا
