پردازنده 64 بیتی
  • nsm
    • 2007/11/09
    • 437
    #1
    پردازنده 64 بیتی
    این موضوع شاید چندان به ARM مربوط نباشه اما خالی از لطف نیست
    پردازنده 4 هسته ای و 64 بیتی
    BCM1480
    BCM1455
    BCM1280
    BCM1255
    برخی از مشخصات:
    Four 64-bit MIPS® CPUs, scalable from 800 MHz–1.2 GHz
    • Quad-issue in-order pipeline with dual-execute and dual-memory pipes
    • Enhanced skew pipeline enables a zero load-to-use penalty
    • 32-KB instruction cache and 32-KB data cache (ECC protected)
    • Fast on-chip multiprocessor bus
    • Connects the CPUs, L2 cache, memory controller, and I/O bridges
    • Runs at half the CPU core frequency and is 256 bits wide
    • On-chip L2 cache
    • 1 MB shared by four CPUs and I/O agents
    • Eight-way associative, ECC protected
    • Any way can be programmed as fast on-chip RAM
    • DDR memory controller
    • Memory bandwidth as high as 100 Gbps
    • Configurable as 2x64-bit or 4x32-bit wide channels
    • Runs up to 400-MHz clock rate, 800-MHz data rate
    • Support for DDR1 and DDR2
    • Three independent, 19.2 full-duplex ports
    • Configurable as 16/8-bit HyperTransport™ (HT) (formerly LDT) or
    Channelized OIF SPI-4 Phase 2
    • Runs up to 600 MHz DDR for aggregate bandwidth of 38.4 Gbps per
    port
    • Includes Intelligent Hash and Filter Engine on each port to route
    packets
    • Supports glueless connectivity of multiple BCM1480 devices to build a
    distributed shared-memory system with hardware-based coherency
    • On-chip switch
    • Connects multiprocessor bus to high-speed interfaces
    • 256-Gbps bisection bandwidth
    • Supports both packet transfer and memory transactions
    • Integrated network and system I/O
    • Four Gigabit-Ethernet MACs configurable as packet FIFO interfaces
    • 64-bit PCI-X interface at 133 MHz
    • Generic I/O for direct connect to boot ROM, flash memory
    • Two SMBus serial configuration interfaces
    • PCMCIA control interface and up to 16 interrupts
    • Four UART interfaces
    • On-chip debug capability
    • EJTAG
    • Bus trace unit (internal logic analyzer)
    • Support for leading operating systems, including VxWorks®, Linux®,
    and QNX®
    هرکه خود را یک بار با اشکهایش شستشو دهد تا زنده است پاک و مقدس میماند
  • nsm
    • 2007/11/09
    • 437
    پاسخ : پردازنده 64 بیتی
    دو مورد آخر 2 هسته ای می باشد
