برنامه نویسی میکرو با labview
  • alishekarriz
    • 2010/06/24
    • 92
    #1
    از دوستان کسی با لب ویو برنامه نویسی کرده برای میکرو .. مخصوصا آرم
    با توجه به گرافیکی بودن و قدرت شبیه سازی باید کار راه انداز باشه . امشب نصبش میکنم ببینم چه کارهایی میتونم بکنم باهاش
    فکر میکنید مستقیم قابلیت پروگرام کردن داره ؟
    دیباگ چی؟
    چه میکروهایی رو پشتیبانی میکنه ؟
    NI LabVIEW Embedded Module for ARM Microcontrollers
    Graphical Programming for ARM7, ARM9, and Cortex-M3
    E-mail this Page Configure Page for: Print PDF Rich Text
    [+] Enlarge Picture
    Works with more than 260 ARM7, ARM9, and Cortex-M3 microcontrollers
    Integrated drivers for analog and digital I/O, PWM, TCP/IP, serial, I2C, and SPI
    Simulate your application on the desktop including peripheral I/O for stimulus/response
    Simple API for integrating C code with graphical
    NI LabVIEW Embedded Module for ARM Microcontrollers Resource Kit
    Questions? Get real-time assistance now!
    Learn about debugging, simulation, and I/O drivers with this collection of technical application notes.
    Kit Contents
    Tutorial: Porting to Another ARM Processor
    Learn how to target LabVIEW code to any custom ARM target. This tutorial is the first document in a four-part series that demonstrates the steps taken to port LabVIEW code to the Phytec LPC3180 ARM9 microcontroller.
    Tutorial: Using the Cycle-Accurate ARM Microcontroller Simulator
    The LabVIEW Embedded Module for ARM Microcontrollers includes support for the RealView µVision ARM simulator, which provides cycle accurate timing and logic simulation. In addition, the simulator supports many of the on-chip peripherals so that you can provide controlled stimulus and response for debugging and testing your application. With this capability, you can develop and test large portions of the application before the hardware design is complete.
    Tutorial: Debugging ARM Microcontroller Applications
    Any software application will inevitably contain bugs during the development cycle. In order to correct these software flaws, developers need access to powerful debugging tools that allow them to be more efficient as well as be able to dig into the detailed operation of their application.
    Tutorial: Interrupt Driven Programming for ARM Microcontrollers Using LabVIEW
    This tutorial will introduce interrupt driven programming and demonstrate the steps required to manage interrupts using the NI LabVIEW Embedded Module for ARM Microcontrollers. Also covered are design decisions to be addressed when using interrupts within applications.
    Tutorial: Optimizing ARM Applications
    This tutorial will describe advanced optimization techniques for developing applications for ARM Microcontrollers. Once an application has been developed these optimizations may be attempted in an effort to squeeze increased performance or reduce the code footprint of a given application.
    Tutorial: Developing ARM Application to Communicate via CAN
    This tutorial covers the how to use the LabVIEW Embedded Module for ARM to communicate over Controller Area Network (CAN) bus. This tutorial assumes that you already have installed LabVIEW for ARM 1.1 and have familiarity building applications for ARM.
  • md3848
    • 2014/05/29
    • 1228
    پاسخ : برنامه نویسی میکرو با labview
    کسی نبود؟
    اللَّهُمَّ صَلِّ عَلَى مُحَمَّدٍ وآلِ مُحَمَّدٍ وعَجِّلْ فَرَجَهُمْ
    اگه دوس دارید سریع به جواب برسید :
    1) قبل از پرسیدن سوال، بسرچید.
    2) سوالاتون رو با جزئیات کامل مطرح کنید.
