من UART0/1/3 رو راه اندازی کردم و از اونها استفاده کردم. ولی UAR2 رو که فعال می کنم . مشکل داره. راه اندازی UART2 نکته داره؟
همین مشکل رو با LPC1788 دارم.
void Init_serial2 (void)
uint16_t usFdiv;
LPC_PINCON->PINSEL0 |= (1 << 20); /* Pin P0.10 used as TXD2 (Com2) */
LPC_PINCON->PINSEL0 |= (1 << 22); /* Pin P0.11 used as RXD2 (Com2) */
LPC_SC->PCONP = LPC_SC->PCONP|(1<<24); /*Open UART2 power control bit */
LPC_UART2->LCR = 0x83; /* Allows you to set the baud rate */
usFdiv = (Fcpu / 16) / BaudRate; /* Set baud rate */
LPC_UART2->DLM = usFdiv / 256;
LPC_UART2->DLL = usFdiv % 256;
LPC_UART2->LCR = 0x03; /* Locked baud rate */
LPC_UART2->IER = 0x01 ; //can be changed only when DLAB=0
LPC_UART2->FCR = 0x07;
NVIC_SetPriority(UART2_IRQn,20); // Default priority group 3, can be 0(highest) - 31(lowest)
NVIC_EnableIRQ(UART2_IRQn); // Enable UART0 Interrupt
void UART2_IRQHandler (void) __irq
unsigned char IIRValue, LSRValue;
IIRValue = LPC_UART2->IIR;
IIRValue >>= 1; // skip pending bit in IIR
IIRValue &= 0x07; // check bit 1~3, interrupt identification
else if ( IIRValue == IIR_RDA ) // Receive Data Available
//Receive Data Available
UART2Buffer[UART2Count] = LPC_UART2->RBR;
sendchar2(UART2Buffer[UART2Count]);
else if ( IIRValue == IIR_CTI ) // Character timeout indicator
// Character Time-out indicator /
UART2Status |= 0x100; // Bit 9 as the CTI error
UART2Count++;
int main (void)
unsigned int i;
Init_serial2();
while(1)
i++;
sendchar2(i);
delay_ms(1000);
UARTPutChar(UART_0,'a');
#include "lpc17xx.h" /* LPC17xx definitions */
#include "uart.h"
#define FPCLK 25000000
#define UART0_BPS 9600 /* 0 Serial communication baud rate */
** Function name: UART0_Init
** Descriptions: By default initialize the serial port 0 pins and communication parameters. Set to 8 data bits, 1 stop bit, no parity
** input parameters: No
** output parameters: No
** Returned value: No
void UART0_Init (void)
uint16_t usFdiv;
/* UART0 */
LPC_SC->PCONP |=(1<<3);
LPC_PINCON->PINSEL0 |= (1 << 4); /* Pin P0.2 used as TXD0 (Com0) */
LPC_PINCON->PINSEL0 |= (1 << 6); /* Pin P0.3 used as RXD0 (Com0) */
LPC_UART0->LCR = 0x83; /* Allows you to set the baud rate */
usFdiv = (FPCLK / 16) / UART0_BPS; /* Set baud rate */
LPC_UART0->DLM =usFdiv / 256;
LPC_UART0->DLL =usFdiv % 256;
//LPC_UART0->FDR=0X43;
LPC_UART0->LCR = 0x03; /* Locked baud rate */
LPC_UART0->FCR =0x07;
LPC_UART0->IER = 0x01;
NVIC_SetPriority(UART0_IRQn,0); /* Default priority group 0, can be 0(highest) - 31(lowest) */
NVIC_EnableIRQ(UART0_IRQn);
** Function name: UART0_SendByte
** Descriptions: send data from serial port 0
** Input parameters: data: data sent
** Output parameters: None
** Returned value: None
void UART0_SendByte (int ch)
while (!(LPC_UART0->LSR & 0x20));
LPC_UART0->THR =ch;
void UART0_SendChar(int disp)
int dispbuf[4];
int i;
dispbuf[3] = disp%10 + '0';
dispbuf[2] = disp/10%10 + '0';
dispbuf[1] = disp/10/10%10 + '0';
dispbuf[0] = disp/10/10/10%10 + '0';
for(i=0;i<4;i++)
UART0_SendByte(dispbuf[i]);
Read character from Serial Port (blocking read)
int UART0_GetChar (void)
while (!(LPC_UART0->LSR & 0x01));
return (LPC_UART0->RBR);
void UART0_SendString (unsigned char *s)
while (*s != 0)
UART0_SendByte(*s++);
