ADC میکروی STM32f103 می تونه مقدار منفی بخونه؟(ورودی ADC چند تا چنده)
پاسخ : ADC میکروی STM32f103 می تونه مقدار منفی بخونه؟
بله میتونه بخونه. مشخصه یکی مونده به آخر رو نگاه کنید:
کد:ADC main features ● 12-bit resolution ● Interrupt generation at End of Conversion, End of Injected conversion and Analog watchdog event ● Single and continuous conversion modes ● Scan mode for automatic conversion of channel 0 to channel ‘n’ ● Self-calibration ● Data alignment with in-built data coherency ● Channel by channel programmable sampling time ● External trigger option for both regular and injected conversion ● Discontinuous mode ● Dual mode (on devices with 2 ADCs or more) ● ADC conversion time: – STM32F103xx performance line devices: 1 μs at 56 MHz (1.17 μs at 72 MHz) – STM32F101xx access line devices: 1 μs at 28 MHz (1.55 μs at 36 MHz) – STM32F102xx USB access line devices: 1.2 μs at 48 MHz – STM32F105xx and STM32F107xx devices: 1 μs at 56 MHz (1.17 μs at 72 MHz) ● ADC supply requirement: 2.4 V to 3.6 V ● ADC input range: VREF- ≤ VIN ≤ VREF+ ● DMA request generation during regular channel conversion
نمی تونه بخونه ، درسته که گفته -Vref اما درون دیتا شیت گفته که -Vref بایستی به زمین وصل بشه.
درون دیتا شیت گفته:
The lower/negative reference voltage for the ADC,VREF- = VSSA
و
Ground for analog power supply equal to VSS
صفحه 209 دیتا شیت STM32F103REمی بینیم و نادیده می گیریم!
