با سلام خدمت دوستان و اساتید؛
کدهای زیادی رو امتحان کردم و نمونه های زیادی رو چک کردم، ولی هرکار می کنم همون اوایل ارتباط گیر میکنه تو این حلقه چک:
[code=c]while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));[/code]
از I2C1 استفاده میکنم و این هم کدهای راه اندازیش:
[code=c]//-----------------------------------------------------------------------------
// Copyright:
// Author:
// Remarks:
// known Problems:
// Version: 0.0.1
// Description: I2C Configuration library (.c)
#include <stm32f10x.h>
#include <stm32f10x_conf.h>
#include "I2C_Configuration.h"
#define I2C_Speed 100000
#define I2C1_SLAVE_ADDRESS7 0xA0
#define I2C_PageSize 4
#define EEPROM_Block0_ADDRESS 0xA0 /* E2 = 0 */
//#define EEPROM_Block1_ADDRESS 0xA2 /* E2 = 0 */
//#define EEPROM_Block2_ADDRESS 0xA4 /* E2 = 0 */
//#define EEPROM_Block3_ADDRESS 0xA6 /* E2 = 0 */
u16 EEPROM_ADDRESS;
void i2cInit(void){
/* Enable PortB Clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE );
/* Enable I2C1 Clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE) ;
/* Configure I2C1 pins */
GPIO_InitTypeDef GPIO_InitStructure;
/* Configure I2C1 pins: SCL and SDA */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* I2C1 Configuration */
I2C_InitTypeDef I2C_InitStructure;
/* I2C configuration */
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = I2C1_SLAVE_ADDRESS7;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = I2C_Speed;
/* I2C Peripheral Enable */
I2C_Cmd(I2C1, ENABLE);
/* Apply I2C configuration after enabling it */
I2C_Init(I2C1, &I2C_InitStructure);
* Function Name : I2C_EE_Init
* Description : Initializes peripherals used by the I2C EEPROM driver.
* Input : None
* Output : None
* Return : None
void I2C_EE_Init()
/* depending on the EEPROM Address selected in the i2c_ee.h file */
#ifdef EEPROM_Block0_ADDRESS
/* Select the EEPROM Block0 to write on */
EEPROM_ADDRESS = EEPROM_Block0_ADDRESS;
#endif
#ifdef EEPROM_Block1_ADDRESS
/* Select the EEPROM Block1 to write on */
EEPROM_ADDRESS = EEPROM_Block1_ADDRESS;
#endif
#ifdef EEPROM_Block2_ADDRESS
/* Select the EEPROM Block2 to write on */
EEPROM_ADDRESS = EEPROM_Block2_ADDRESS;
#endif
#ifdef EEPROM_Block3_ADDRESS
/* Select the EEPROM Block3 to write on */
EEPROM_ADDRESS = EEPROM_Block3_ADDRESS;
#endif
* Function Name : I2C_EE_BufferWrite
* Description : Writes buffer of data to the I2C EEPROM.
* Input : - pBuffer : pointer to the buffer containing the data to be
* written to the EEPROM.
* - WriteAddr : EEPROM's internal address to write to.
* - NumByteToWrite : number of bytes to write to the EEPROM.
* Output : None
* Return : None
void I2C_EE_BufferWrite(u8* pBuffer, u8 WriteAddr, u16 NumByteToWrite)
u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
Addr = WriteAddr % I2C_PageSize;
count = I2C_PageSize - Addr;
NumOfPage = NumByteToWrite / I2C_PageSize;
NumOfSingle = NumByteToWrite % I2C_PageSize;
/* If WriteAddr is I2C_PageSize aligned */
if(Addr == 0)
/* If NumByteToWrite < I2C_PageSize */
if(NumOfPage == 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, NumOfSingle);
I2C_EE_WaitEepromStandbyState();
/* If NumByteToWrite > I2C_PageSize */
else
while(NumOfPage--)
I2C_EE_PageWrite(pBuffer, WriteAddr, I2C_PageSize);
WriteAddr += I2C_PageSize;
pBuffer += I2C_PageSize;
if(NumOfSingle!=0)
/* If WriteAddr is not I2C_PageSize aligned */
else
if(NumOfPage== 0)
else
NumByteToWrite -= count;
if(count != 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, count);
WriteAddr += count;
pBuffer += count;
while(NumOfPage--)
if(NumOfSingle != 0)
* Function Name : I2C_EE_ByteWrite
* Description : Writes one byte to the I2C EEPROM.
* Output : None
* Return : None
void I2C_EE_ByteWrite(u8* pBuffer, u8 WriteAddr)
/* Send STRAT condition */
I2C_GenerateSTART(I2C1, ENABLE);
/* Test on EV5 and clear it */
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
/* Send EEPROM address for write */
I2C_Send7bitAddress(I2C1, EEPROM_ADDRESS, I2C_Direction_Transmitter);
/* Test on EV6 and clear it */
/* Send the EEPROM's internal address to write to */
I2C_SendData(I2C1, WriteAddr);
/* Test on EV8 and clear it */
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
/* Send the byte to be written */
I2C_SendData(I2C1, *pBuffer);
/* Send STOP condition */
I2C_GenerateSTOP(I2C1, ENABLE);
* Function Name : I2C_EE_PageWrite
* Description : Writes more than one byte to the EEPROM with a single WRITE
* cycle. The number of byte can't exceed the EEPROM page size.
* Output : None
* Return : None
void I2C_EE_PageWrite(u8* pBuffer, u8 WriteAddr, u8 NumByteToWrite)
/* While the bus is busy */
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
/* Send START condition */
while(! I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
/* While there is data to be written */
while(NumByteToWrite--)
/* Send the current byte */
/* Point to the next byte to be written */
pBuffer++;
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
* Function Name : I2C_EE_BufferRead
* Description : Reads a block of data from the EEPROM.
* Input : - pBuffer : pointer to the buffer that receives the data read
* from the EEPROM.
* - ReadAddr : EEPROM's internal address to read from.
* - NumByteToRead : number of bytes to read from the EEPROM.
* Output : None
* Return : None
void I2C_EE_BufferRead(u8* pBuffer, u8 ReadAddr, u16 NumByteToRead)
/* Clear EV6 by setting again the PE bit */
I2C_SendData(I2C1, ReadAddr);
/* Send STRAT condition a second time */
/* Send EEPROM address for read */
I2C_Send7bitAddress(I2C1, EEPROM_ADDRESS, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
/* While there is data to be read */
while(NumByteToRead)
if(NumByteToRead == 1)
/* Disable Acknowledgement */
I2C_AcknowledgeConfig(I2C1, DISABLE);
/* Send STOP Condition */
/* Test on EV7 and clear it */
if(I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
/* Read a byte from the EEPROM */
*pBuffer = I2C_ReceiveData(I2C1);
/* Point to the next location where the byte read will be saved */
pBuffer++;
/* Decrement the read bytes counter */
NumByteToRead--;
/* Enable Acknowledgement to be ready for another reception */
I2C_AcknowledgeConfig(I2C1, ENABLE);
* Function Name : I2C_EE_WaitEepromStandbyState
* Description : Wait for EEPROM Standby state
* Input : None
* Output : None
* Return : None
void I2C_EE_WaitEepromStandbyState(void)
vu16 SR1_Tmp = 0;
do
/* Read I2C1 SR1 register */
SR1_Tmp = I2C_ReadRegister(I2C1, I2C_Register_SR1);
}while(!(I2C_ReadRegister(I2C1, I2C_Register_SR1) & 0x0002));
/* Clear AF flag */
I2C_ClearFlag(I2C1, I2C_FLAG_AF);
/* STOP condition */
[/code]
ممنون میشم اگه دوستان تجربه ای دارن کمک کنن.
پ.ن: پایه های I2C پول پ شدن و پایه های آدرس دهی at24c01 هم طبق گفته دیتاشیت واسه آدرس عمومیش Gnd شدن.
// Copyright:
// Author:
// Remarks:
// known Problems:
// Version: 0.0.1
u16 EEPROM_ADDRESS;
void i2cInit(void){
* Input : None
* Output : None
* Return : None
void I2C_EE_Init()
#endif
#endif
#endif
#endif
* Output : None
* Return : None
if(Addr == 0)
if(NumOfPage == 0)
else
while(NumOfPage--)
if(NumOfSingle!=0)
else
if(NumOfPage== 0)
else
if(count != 0)
WriteAddr += count;
pBuffer += count;
while(NumOfPage--)
* Output : None
* Return : None
* Output : None
* Return : None
pBuffer++;
* from the EEPROM.
* Output : None
* Return : None
pBuffer++;
NumByteToRead--;
* Input : None
* Output : None
* Return : None
vu16 SR1_Tmp = 0;
do
/* Clear AF flag */
[/code]
