*** چگونگی رفع خطا در برنامه ی میکروکنترلر stm8s003f3 در نرم افزار iar
    من این برنامه رو برای میکرو stm8s نوشتم اما این خطا رو میده
    Error[Li005]: no definition for "GPIO_Init" [referenced from D:\iar_software\project\Debug\Obj\main.o]
    Error[Li005]: no definition for "GPIO_WriteReverse" [referenced from D:\iar_software\project\Debug\Obj\main.o]
    چطور باید این مشکل رو حل کنم
    [FONT=Yekan]/**[/FONT]  ******************************************************************************
      * @file    GPIO_Toggle\main.c
      * [MENTION=19064]autho[/MENTION]r  MCD Application Team
      * @version V2.0.4
      * @date    26-April-2018
      * @brief   This file contains the main function for GPIO Toggle example.
      * @attention
      * <h2><center>&copy; COPYRIGHT 2014 STMicroelectronics</center></h2>
      * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
      * You may not use this file except in compliance with the License.
      * You may obtain a copy of the License at:
      *        [url]http://www.st.com/software_license_agreement_liberty_v2[/url]
      * Unless required by applicable law or agreed to in writing, software
      * distributed under the License is distributed on an "AS IS" BASIS,
      * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
      * See the License for the specific language governing permissions and
      * limitations under the License.
    /* Includes ------------------------------------------------------------------*/
    #include "stm8s.h"
    #include "stm8s_gpio.h"
    #include "stm8s_conf.h"
      * @addtogroup GPIO_Toggle
    /* Private typedef -----------------------------------------------------------*/
    /* Private define ------------------------------------------------------------*/
    /* Evalboard I/Os configuration */
    #define LED_GPIO_PORT  (GPIOA)
    #define LED_GPIO_PINS  (GPIO_PIN_3 | GPIO_PIN_2 | GPIO_PIN_1 | GPIO_PIN_0)
    /* Private macro -------------------------------------------------------------*/
    /* Private variables ---------------------------------------------------------*/
    /* Private function prototypes -----------------------------------------------*/
    void Delay (uint16_t nCount);
    /* Private functions ---------------------------------------------------------*/
    /* Public functions ----------------------------------------------------------*/
      * @brief  Main program.
      * [MENTION=17545]para[/MENTION]m  None
      * @retval None
    void main(void)
      /* Initialize I/Os in Output Mode */
      GPIO_Init(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS, GPIO_MODE_OUT_PP_LOW_FAST);
      while (1)
        /* Toggles LEDs */
        GPIO_WriteReverse(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS);
        Delay(0xFFFF);
      * @brief Delay
      * [MENTION=17545]para[/MENTION]m nCount
      * @retval None
    void Delay(uint16_t nCount)
      /* Decrement nCount value */
      while (nCount != 0)
        nCount--;
    #ifdef USE_FULL_ASSERT
      * @brief  Reports the name of the source file and the source line number
      *   where the assert_param error has occurred.
      * [MENTION=17545]para[/MENTION]m file: pointer to the source file name
      * [MENTION=17545]para[/MENTION]m line: assert_param error line source number
      * @retval None
    void assert_failed(uint8_t* file, uint32_t line)
      /* User can add his own implementation to report the file name and line number,
         ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
      /* Infinite loop */
      while (1)
    #endif
    /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
    پاسخ : *** چگونگی رفع خطا در برنامه ی میکروکنترلر stm8s003f3 در نرم افزار iar
    نوشته اصلی توسط farshad_1372 نمایش پست ها
      * @[URL="https://www.eca.ir/forums/member.php?u=19064"]autho[/URL]r  MCD Application Team
      * @version V2.0.4
      * @attention
      *        [URL]http://www.st.com/software_license_agreement_liberty_v2[/URL]
    #include "stm8s.h"
      * @[URL="https://www.eca.ir/forums/member.php?u=17545"]para[/URL]m  None
      * @retval None
    void main(void)
      while (1)
        /* Toggles LEDs */
        Delay(0xFFFF);
      * @brief Delay
      * @[URL="https://www.eca.ir/forums/member.php?u=17545"]para[/URL]m nCount
      * @retval None
      while (nCount != 0)
        nCount--;
      * @[URL="https://www.eca.ir/forums/member.php?u=17545"]para[/URL]m file: pointer to the source file name
      * @[URL="https://www.eca.ir/forums/member.php?u=17545"]para[/URL]m line: assert_param error line source number
      * @retval None
      /* Infinite loop */
      while (1)
    #endif
    داره میگه GPIO_Init و GPIO_WriteReverse تعریف نشدن. احتمالا یا هدرهای لازم رو به برنامه اضافه نکردید، یا اصلا همچین چیزهایی وجود ندارن و دارید اشتباه میکنید!
      سلام دوستان با میکرو stm8s دارم کد میزنم این خطا تو iar اومده چطور باید حلش کنم ؟؟http://s12.picofile.com/file/8400163092/d4.bmp
      جدیدترین ویرایش توسط farshad_1372; 2020/06/15, 23:14.
        از محیط برنامه نویسی VSCode و کامپایلر Cosmic-stm8 که هردو رایگان هستن استفاده کنید.
        سایت سیسوگ آموزش های خوبی داره و برای تمام امکانات این میکروها مقاله گذاشته.
          نوشته اصلی توسط saleh.yari نمایش پست ها
          پیشنهاد خوبیه ،
          ولی مطمئنا کامپایلر SDCC با محیط VS Code خیلی بهتر هست.
