سلام دوستان عزیز
من نمیتوانم برنامه های که نوشته ام و صد در صد هم کار میند در برنامه Proteus 6 اجرا نمایم پیغام زیر میآید.اگر کسی میتواند من را راهنمایی کند متشکر میشوم . اگر مثال هم دارید لطفا برایم بدهید . باز تشکر
SIMULATION LOG
Design: C:\Program Files\Labcenter Electronics\Proteus 6 Professional\mpc\frequency meter.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author: <NONE>
Created: 02/03/18
Modified: 02/03/18
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [3DA11449]...
Animation started sucessfully...
PROSPICE Release 6.2 SP0 (C) Labcenter Electronics 1993-2002.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Building circuit...
Added GEARTH resistor for net #00023.
Added GEARTH resistor for net #00024.
Added GEARTH resistor for net #00029.
Instantiating SPICE models...
[U1] AVR model release 6.2 SP0.
[U1] Loaded 512 bytes of persistent EEPROM data.
ERROR: [U1] Must specify file extension for PROGRAM property.
Warning: [U1] No program code loaded.
[DSIM] BOOT Error.
Real Time Simulation failed to start
Real Time Simulation FAILED.
Doc. no.: <NONE>
Revision: <NONE>
Author: <NONE>
Created: 02/03/18
Modified: 02/03/18
Build completed OK.
Linking netlist...
Reading netlist...
Building circuit...
[DSIM] BOOT Error.
