پاسخ : کارت اسیلوسکوپ
این امکانات این اسیلوسکوپیه که می خوام بگیرم . 100 مگا سمپل بر ثانیه و 40 مگا هرتز /
در کل مشکلی نداره ؟
GAO2090 USB PC Based Oscilloscope - Characteristic:
USB2.0 interface, no external power source required, easy to use.
be suitable for notebook computer-product line maintenance.
Dimensions (mm):190(L) x100(W) x35(H), be carried easily.
High performance, 100MS/s real-time sampling, 40MHz Bandwidth.
Operating System: Windows98,Windows Me, Windows NT, Windows 2000, Windows XP , VISTA
23 measurement functions, PASS/FAIL Check, suitable for technical application.
Waveform average, persistence, intensity, invert, addition, subtraction, multiplication, division, X-Y plot.
Save waveform in the following: text file, jpg/bmp graphic file, MS excel/word file.
FFT
One computer can connect many DSO, extend channel easily.
LabviewVBVCDelphiC++Build Second Design instance.
Back to Top
GAO2090 USB PC Based Oscilloscope - Hardware Specifications:
Channel
2 Channels
Impedance
1M? 25pF
Coupling
AC/DC/GND
Vertical resolution
8Bit
Gain range
10mV-5V, 9Steps
DC accuracy
±3%
Timebase range
4ns-1h, 38 Steps
Vertical adjustable
Yes
Input protection
Diode clamping
X-Y
Yes
Autoset
Yes (30Hz to 40MHz)
EXT. input
DC -40MHz
Trigger Mode
Auto, Normal and Single
Trigger Slope
Trigger level adjustable
Yes
Trigger Type
Rising edge, falling edge
Trigger Source
CH1, CH2, EXT
Pre/Post trigger
0-100%
Buffer size
10K-32KB/Channel
Shot bandwidth
DC to 40MHz
Max. Sample rate
100MS/s
Sampling selection
Yes
Waveform Display
port/line, waveform average, persistence, intensity
Network
Open/Close
Vertical mode
CH1, CH2, Dual, ADD
Cursor measurement
Yes
Spectrum analyzer
Channel
2 Channels
Math
FFT, addition, subtraction, multiplication, division.
Bandwidth
40MHz
دوستان خواهش میکنم.
هر چیزی که میدونین رک بگین. چون من تصمیم دارم اینو اینترنتی بخرم . اگه بده میخوام همین الان منصرف شم.
مدل مشابه با قیمت خوب دارین پیشنهاد بدین.
http://www.gaotek.com/index.php?main_page=product_info&products_id=8 44&zenid=da6be989608e6aa1298d6bab6c6ecb43
ممنون.
در کل مشکلی نداره ؟
FFT
Back to Top
Channel
2 Channels
Impedance
1M? 25pF
Coupling
AC/DC/GND
Vertical resolution
8Bit
Gain range
10mV-5V, 9Steps
DC accuracy
±3%
Timebase range
4ns-1h, 38 Steps
Vertical adjustable
Yes
Input protection
Diode clamping
X-Y
Yes
Autoset
Yes (30Hz to 40MHz)
EXT. input
DC -40MHz
Trigger Mode
Trigger Slope
Yes
Trigger Type
Trigger Source
CH1, CH2, EXT
Pre/Post trigger
0-100%
Buffer size
10K-32KB/Channel
Shot bandwidth
DC to 40MHz
Max. Sample rate
100MS/s
Sampling selection
Yes
Waveform Display
Network
Open/Close
Vertical mode
CH1, CH2, Dual, ADD
Cursor measurement
Yes
Spectrum analyzer
Channel
2 Channels
Math
Bandwidth
40MHz
دوستان خواهش میکنم.
ممنون.
