پاسخ : {دانلود}-برنامه کامل و بدون نقص SIM900 به زبان بسکام -کنترل چند رله و سنسور
حذف شد :biggrin:
حذف شد :biggrin:
'Designed By NimaAriyamehr
$regfile = "m32def.dat"
$crystal = 8000000
$baud = 9600
Config Lcdpin = Pin , Db4 = Portb.0 , Db5 = Portb.1 , Db6 = Portb.2 , Db7 = Portb.3 , E = Portb.4 , Rs = Portb.5
Config Lcd = 16 * 2
$hwstack = 64
$swstack = 64
$framesize = 64
Config Debounce = 200 'Set 150ms as Debounce delay
Config Porta.0 = Output
Config Porta.1 = Output
Config Porta.2 = Output
Config Portd.6 = Output
Config Pind.2 = Input
Config Pind.7 = Input
Config Pinc.0 = Input
Declare Sub Getline
Declare Sub Send_sms
Declare Sub Sms_check
Declare Sub Dail
Declare Sub Chenge_pass
Declare Sub Mony
Deflcdchar 1 , 31 , 21 , 14 , 4 , 4 , 4 , 4 , 4
Deflcdchar 2 , 1 , 1 , 1 , 5 , 5 , 5 , 21 , 21
Deflcdchar 3 , 32 , 14 , 10 , 21 , 21 , 17 , 31 , 32
Deflcdchar 4 , 32 , 17 , 25 , 21 , 19 , 17 , 32 , 32
Relay1 Alias Porta.0
Relay2 Alias Porta.1
Relay3 Alias Porta.2
Pwr Alias Portd.6
Ri Alias Pind.2
Sens1 Alias Pind.7
Sens2 Alias Pinc.0
Dim Listen As Eram Byte
Dim Alarm As Eram Byte
Dim Status1 As Eram Byte
Dim Status2 As Eram Byte
Dim Status3 As Eram Byte
Dim Number As Eram String * 13
Dim Sms As Eram Byte
Dim Pass As Eram String * 4
Dim Pass2 As Eram String * 3
'------------ Variables and constants for GSM --------------------------------- ------
Dim Num As String * 80
Dim Num2 As String * 80
Dim Msg As String * 160
Dim Inmsg As String * 160
Dim Gstmp As Byte
Dim Ar(10) As String * 20
Dim Count As Byte
Dim Gps As Byte
Dim Pass_stored As String * 13
Dim Sharj As String * 160
Dim S As Byte
Dim X As Byte
Dim Rly1 As String * 3
Dim Rly2 As String * 3
Dim Rly3 As String * 3
Dim Rly4 As String * 3
Dim Alrm As String * 3
Dim P1 As String * 4
Dim P2 As String * 3
Dim Body As Bit
Relay1 = 0
Relay2 = 0
Relay3 = 0
Ri = 1
Sens1 = 1
Sens2 = 1
S = 2
Body = 0
If Sms = 1 Then
Sms = 1
Else
Sms = 0
End If
If Alarm = 1 Then
Alrm = "on"
Else
Alrm = "Off"
End If
Cursor Off
P2 = Pass2
If P2 = "OK" Then
Cls : Lcd "HAVE OLD PASS"
Wait 2
Else
Pass = "1111"
Cls : Lcd "Default Pass Is:" : Locate 2 , 7 : Lcd "1111"
Wait 2
End If
P1 = Pass
Pass_stored = Number
Gps = Status1
If Gps = 1 Then
Relay1 = 1
Rly1 = "on"
Else
Relay1 = 0
Rly1 = "off"
End If
Gps = Status2
If Gps = 1 Then
Relay2 = 1
Rly2 = "on"
Else
Relay2 = 0
Rly2 = "Off"
End If
Gps = Status3
If Gps = 1 Then
Relay3 = 1
Rly3 = "on"
Else
Relay3 = 0
Rly3 = "off"
End If
Cls
Locate 1 , 3 'Clear display
Lcd "Initializing"
Locate 2 , 6
Lcd "Modem..."
Set Pwr
Wait 2
Reset Pwr
Wait 5 ' give some time for gsm modem
Print "AT"
Wait 2
Print "AT+CMGD=0,4"
Wait 2
Print "AT+CREG?"
Wait 2
Print "ATE0" '
Wait 2
Print "AT+CNMI=1,1,0,0,0" 'new message indication off
Wait 2 'Third command TEXT MODE
Print "AT+CMGF=1"
Wait 1
Print "AT"
Wait 1
M:
'********************************** SENSORHAA****************************
If Alarm = 1 Then
If Sens1 = 0 Then
If Sens1 = 1 Then
Cls
Num = Pass_stored
Lcd "===>SENSED 1<==="
Msg = "Amotion IN SENSOR 1 "
If Sms = 1 Then Send_sms
If Sms = 0 Then Dail
Goto P
End If
End If
If Sens2 = 0 Then
If Sens2 = 1 Then
Cls
Num = Pass_stored
Lcd "===>SENSED 2<=== "
Msg = "Amotion IN SENSOR 2 "
Goto P
End If
End If
End If
'*********************************Message Sense*******************************************
If Ri = 0 Then S = 0
If S < 3 Then
Incr S
Print "AT"
Wait 2
Print "AT+CMGR=1" ' get the message
Getline
If Inmsg <> "OK" Then
Num = Inmsg
Getline
Gps = Split(num , Ar(1) , ",")
Num = Ar(2)
Gps = Len(num)
Gps = Gps - 2
Num = Mid(num , 2 , Gps)
Inmsg = Lcase(inmsg)
If Inmsg = P1 Then 'password is 333
Cls
Locate 1 , 1
Lcd "===>Password<==="
Locate 2 , 1
Lcd "===>Accepted<==="
Pass_stored = Num
Number = Pass_stored
Num2 = Num
Msg = "Password Accepted"
Body = 1
' If Sms = 0 Then Dail
Elseif Num = Pass_stored Then
Body = 1
Cls
Lcd "Control msg Rciv"
If Inmsg = "1-on" Then '1-on
Relay1 = 1
Status1 = 1
Rly1 = "On"
Num = Pass_stored
Msg = "Light Switched ON"
Elseif Inmsg = "1-off" Then '1-off
Relay1 = 0
Status1 = 0
Rly1 = "off"
Num = Pass_stored
Msg = "Light Switched OFF"
Elseif Inmsg = "2-on" Then
Relay2 = 1
Status2 = 1
Rly2 = "On"
Num = Pass_stored
Msg = "Fan Switched ON"
Elseif Inmsg = "2-off" Then
Relay2 = 0
Status2 = 0
Rly2 = "Off"
Num = Pass_stored
Msg = "Fan Switched OFF"
Elseif Inmsg = "3-on" Then
Relay3 = 1
Status3 = 1
Rly3 = "On"
Num = Pass_stored
Msg = "AC Switched ON"
Elseif Inmsg = "3-off" Then
Relay3 = 0
Status3 = 0
Rly3 = "Off"
Num = Pass_stored
Msg = "AC Switched OFF"
Elseif Inmsg = "status" Then
Cls
Lcd " Status Checked"
Num = Pass_stored
Msg = "1 is :" + Rly1 + "--" + " 2 is :" + Rly2 + "--" + " 3 is :" + Rly3 + "--" + " Securt is: " + Alrm
Send_sms
Elseif Inmsg = "pass" Then
Msg = "Security password Is=> (" + P1 + ")"
Send_sms
Elseif Inmsg = "Listen-on" Then
Num = Pass_stored
Listen = 1
Cls
Lcd "Listen On"
Msg = "Listen Mod ON"
Send_sms
Elseif Inmsg = "Listen-off" Then
Listen = 0
Cls
Lcd "Listen Off"
Msg = "Listen Mod Off"
Send_sms
Elseif Inmsg = "new-pass" Then
Chenge_pass
Elseif Inmsg = "all-off" Then
Relay1 = 0
Status1 = 0
Relay2 = 0
Status2 = 0
Relay3 = 0
Status3 = 0
Num = Pass_stored
Msg = "ALL Channel Switched OFF"
Elseif Inmsg = "alarm-on" Then
Num = Pass_stored
Alarm = 1
Cls : Lcd "Secqrity On"
Msg = "Secqrity System Swiched On"
Elseif Inmsg = "alarm-off" Then
Num = Pass_stored
Alarm = 0
Cls : Lcd "Secqrity Off"
Msg = "Secqrity System Swiched Off"
Elseif Inmsg = "dail" Then
Num = Pass_stored
Sms = 0
Cls : Lcd "===>Dail Mod<==="
Msg = "DAIL MOD"
Dail
Elseif Inmsg = "sms" Then
Num = Pass_stored
Sms = 1
Cls : Lcd "===>Sms Mod<==="
Msg = "SMS MOD"
Elseif Inmsg = "exit" Then
Cls : Lcd "=>DELET NUMBER<="
Msg = "This Number Romoved From Sysyem!"
Body = 0
Pass_stored = "0"
Num = "1"
Number = "2"
Elseif Inmsg = "sharj" Then ' ********************
Num = Pass_stored
Mony
Cls
Lcd Sharj ; "Rial"
Msg = Sharj + "Rial"
Send_sms
If Sharj < "1000" Then
Dail
End If
Wait 3
Else
Num = Pass_stored
Cls
Lcd "Error Msg"
End If
Else
Cls
Locate 1 , 3
Lcd "ERROR PASS"
Wait 1
Cls
End If
P:
Wait 1
Print "AT+CMGD=0,4"
Wait 1
Cls
Cursor Off
Locate 1 , 4
Lcd "{System}"
Locate 2 , 4
Lcd "{Online}"
Locate 1 , 15 : Lcd Chr(1)
Locate 1 , 16 : Lcd Chr(2)
If Alarm = 1 Then
Locate 1 , 14 : Lcd Chr(3)
End If
If Body = 0 Then
Locate 1 , 13 : Lcd Chr(4)
End If
If Sms = 1 Then
Locate 1 , 1 : Lcd "S"
Else
Locate 1 , 1 : Lcd "D"
Locate 2 , 1 : Lcd Chr(135)
Locate 2 , 13 : Lcd Sharj
End If
End If
End If
End
' SEND SMS
Sub Send_sms
Wait 1
Print "AT+CMGS=" ; Chr(34) ; Num ; Chr(34) 'send sms
Waitms 200
Print Msg ; Chr(26)
Wait 5
Print "AT"
Wait 1
End Sub
' Read gsm modem AND WAITING FOR SMS
Sub Getline
Inmsg = ""
Gps = Inkey()
If Gps > 0 Then
Select Case Gps
Case 13 : If Inmsg <> "" Then Exit Do ' if we have received something
Case 10 : If Inmsg <> "" Then Exit Do ' if we have received something
Case Else
Inmsg = Inmsg + Chr(gps) ' build string
End Select
End If
End Sub
Sub Dail
Print "ATD" ; Num ; ";"
Wait 10
Print "ATH"
End Sub
Sub Chenge_pass
Print "AT+CMGD=0,4"
Wait 1
Msg = "Please Send new pass-4 Raghami OR send Cancel"
Send_sms
Cls : Lcd "Wait For New pass"
Wait 2
Getline
Num = Inmsg
Getline
Num = Ar(2)
Gps = Len(num)
Gps = Gps - 2
If Num <> Num2 Then Goto M ' for More Security
If Inmsg = "cancel" Then Goto P
Pass = Inmsg
P1 = Pass
Pass2 = "OK"
Cls : Lcd "Pass Recived"
Msg = "Succesfull chenged password"
Send_sms
Goto P
End If
End Sub
Sub Mony
Print "ATD*140*1#"
Getline
Getline
Sharj = Left(inmsg , 77)
Sharj = Right(sharj , 6)
Sharj = Ltrim(sharj)
End Sub
Cls Locate 1 , 3 'Clear display Lcd "Initializing" Locate 2 , 6 Lcd "Modem..." Set Pwr Wait 2 Reset Pwr
