سلام .
من هنگام compile کردن برنامه به چنین خطایی مواجه میشم
برنامه :
و خطای داده شده
کسی میتونه بگه چطور می تونم خطا را رفع کنم
برنامه :
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use ieee.std_logic_arith.all;
package my_package is
constant p:integer:=96;
constant z:integer:=96;
constant max_value:integer:=127;
type matrix1x8 is array (1 to 8) of integer range -127 to 127;
type matrix1152x8 is array (1 to 1152) of matrix1x8;
type matrix1x1152i is array (1 to 1152) of integer range -127 to 127;
type matrix1x1152b8 is array( 1 to 1152) of bit_vector(1 to 8);
end my_package;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use work.my_package.all;
entity first_stage is
port (clk:in bit;M:in matrix1152x8;
out_1:out matrix1x1152i;
sign_value:out matrix1x1152b8);
end ;
architecture behave of first_stage is
signal i:integer range -127 to 127:=1;
signal M_1,M_2 :matrix1x8;
signal out_01 ,out_02 : integer;
signal sign_value_01,sign_value_02:bit_vector(1 to 8);
begin
M_1<=M(1+(i-1)*p);
M_2<=M(2+(i-1)*p);
out_1(01+(i-1)*p)<=out_01;
out_1(02+(i-1)*p)<=out_02;
sign_value(1+(i-1)*p)<=sign_value_01;
sign_value(2+(i-1)*p)<=sign_value_02;
-- process (clk_CNP)
-- --begin
--if clk_CNP'event and clk_CNP='1' then
-- i<=i+1;
-- end if;
--end process;
end;
** Error: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(22): Nonresolved signal 'out_1' has multiple sources. Drivers: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(36):Conditional signal assignment line__36 C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(37):Conditional signal assignment line__37 ** Error: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(23): Nonresolved signal 'sign_value' has multiple sources. Drivers: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(40):Conditional signal assignment line__40 C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(41):Conditional signal assignment line__41 ** Error: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(49): VHDL Compiler exiting
