خطا در اجرای برنامه Nonresolved signal has multiple sourcesl
    سلام .
    من هنگام compile کردن برنامه به چنین خطایی مواجه میشم
    برنامه :
    	library IEEE;
    use IEEE.STD_LOGIC_1164.all;
    use ieee.std_logic_arith.all;
    package my_package is
    	 constant p:integer:=96;
    	 constant z:integer:=96;
    	 constant max_value:integer:=127;
    	type matrix1x8  is array (1 to 8) of integer range -127 to 127;
    	type matrix1152x8 is array (1 to 1152) of matrix1x8;
    	type matrix1x1152i is array (1 to 1152) of integer range -127 to 127;
        type matrix1x1152b8 is array( 1 to 1152) of bit_vector(1 to 8);
    end my_package;
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.NUMERIC_STD.ALL;
    use work.my_package.all;
    entity first_stage is
    port (clk:in bit;M:in matrix1152x8;
    		 out_1:out matrix1x1152i;
    		 sign_value:out matrix1x1152b8);
    end ;
    architecture behave of first_stage is
    signal i:integer range -127 to 127:=1;
    signal M_1,M_2 :matrix1x8;
    signal out_01 ,out_02 : integer;
    signal sign_value_01,sign_value_02:bit_vector(1 to 8);
    begin
    	M_1<=M(1+(i-1)*p);
    	M_2<=M(2+(i-1)*p);
    	out_1(01+(i-1)*p)<=out_01;
    	out_1(02+(i-1)*p)<=out_02;
    	sign_value(1+(i-1)*p)<=sign_value_01;
    	sign_value(2+(i-1)*p)<=sign_value_02;
    --	process (clk_CNP)
    --	--begin
    	--if clk_CNP'event and clk_CNP='1' then
    	--	i<=i+1;
    	--	end if;
    	--end process;
    end;
    و خطای داده شده
    ** Error: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(22): Nonresolved signal 'out_1' has multiple sources.
     Drivers:
      C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(36):Conditional signal assignment line__36
      C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(37):Conditional signal assignment line__37
    ** Error: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(23): Nonresolved signal 'sign_value' has multiple sources.
     Drivers:
      C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(40):Conditional signal assignment line__40
      C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(41):Conditional signal assignment line__41
    ** Error: C:/modeltech_6.4/examples/test/cnp_first_stage.vhd(49): VHDL Compiler exiting
    کسی میتونه بگه چطور می تونم خطا را رفع کنم
    دنیا آنقدر وسیع هست که برای همه مخلوقات جایی باشد پس به جای آنکه جای کسی را بگیریم تلاش کنیم جای واقعی خود را بیابیم
    پاسخ : خطا در اجرای برنامه Nonresolved signal has multiple sourcesl
    این مشکل موقعی رخ می دهد که شما یک سیگنال یا پورت را همزمان به بیش از یک مدار یا سیگنال که با هم سنخیت ندارند وصل کنید. مثلا یک سیگنال را هم به زمین وصل کنید و هم به ورودی یک مدار دیگر.
    در مورد out_1 همین اتفاق افتاده . شما آن را به دو جا و همزمان متصل کردید که با هم سنخیت ندارند
    برای حل این مشکل باید در برنامه تعیین کنید که out_1 در چه صورت به out_01 و در چه صورت به out_02 متصل شود.
    یک نکته : در برنامه نویسی HDL در واقع ما با مدارات سروکار داریم نه با عبارات دستوری. مثلا وقتی یک متغیر را مقدار دهی می کنید در واقع یک مدار را به مدار دیگر وصل می کنید. بنابراین در کد نویسی باید دید مداری داشت
      out_1 یک ماتریس دو سطری است
      که هر سطر را به یک سیگنال می دهد .
      نباید چنین خطایی بده.
        مشکل حل شد.پورت های خروجی هر component باید در داخل پروسه انتقال داده شوند
