سلام به دوستان.
کسی هست بتونه مثال مربوط به خواندن از mmc توی کتاب مظاهریانو (مرجع کامل avr) تحلیل کنه؟
با تشکر.
با تشکر.
#include <mega32.h>
#include <delay.h>
#define MMC_CS_PORT PORTB
#define MMC_CS_DDR DDRB
#define MMC_CS_PIN 4
// MMC commands (taken from sandisk MMC reference)
#define MMC_GO_IDLE_STATE 0 ///< initialize card to SPI-type access
#define MMC_SEND_OP_COND 1 ///< set card operational mode
#define MMC_SEND_CSD 9 ///< get card's CSD
#define MMC_SEND_CID 10 ///< get card's CID
#define MMC_SEND_STATUS 13
#define MMC_SET_BLOCKLEN 16 ///< Set number of bytes to transfer per block
#define MMC_READ_SINGLE_BLOCK 17 ///< read a block
#define MMC_WRITE_BLOCK 24 ///< write a block
#define MMC_PROGRAM_CSD 27
#define MMC_SET_WRITE_PROT 28
#define MMC_CLR_WRITE_PROT 29
#define MMC_SEND_WRITE_PROT 30
#define MMC_TAG_SECTOR_START 32
#define MMC_TAG_SECTOR_END 33
#define MMC_UNTAG_SECTOR 34
#define MMC_TAG_ERASE_GROUP_START 35 ///< Sets beginning of erase group (mass erase)
#define MMC_TAG_ERARE_GROUP_END 36 ///< Sets end of erase group (mass erase)
#define MMC_UNTAG_ERASE_GROUP 37 ///< Untag (unset) erase group (mass erase)
#define MMC_ERASE 38 ///< Perform block/mass erase
#define MMC_CRC_ON_OFF 59 ///< Turns CRC check on/off
// R1 Response bit-defines
#define MMC_R1_BUSY 0x80 ///< R1 response: bit indicates card is busy
#define MMC_R1_PARAMETER 0x40
#define MMC_R1_ADDRESS 0x20
#define MMC_R1_ERASE_SEQ 0x10
#define MMC_R1_COM_CRC 0x08
#define MMC_R1_ILLEGAL_COM 0x04
#define MMC_R1_ERASE_RESET 0x02
#define MMC_R1_IDLE_STATE 0x01
// Data Start tokens
#define MMC_STARTBLOCK_READ 0xFE ///< when received from card, indicates that a block of data will follow
#define MMC_STARTBLOCK_WRITE 0xFE ///< when sent to card, indicates that a block of data will follow
#define MMC_STARTBLOCK_MWRITE 0xFC
// Data Stop tokens
#define MMC_STOPTRAN_WRITE 0xFD
// Data Error Token values
#define MMC_DE_MASK 0x1F
#define MMC_DE_ERROR 0x01
#define MMC_DE_CC_ERROR 0x02
#define MMC_DE_ECC_FAIL 0x04
#define MMC_DE_OUT_OF_RANGE 0x04
#define MMC_DE_CARD_LOCKED 0x04
// Data Response Token values
#define MMC_DR_MASK 0x1F
#define MMC_DR_ACCEPT 0x05
#define MMC_DR_REJECT_CRC 0x0B
#define MMC_DR_REJECT_WRITE_ERROR 0x0D
void mmcInit(void);
unsigned char mmcReset(void);
unsigned char mmcSendCommand(unsigned char cmd, unsigned long int argument);
unsigned char mmcRead(unsigned long int sector, unsigned char* buffer);
unsigned char mmcWrite(unsigned long int sector, unsigned char* buffer);
unsigned char mmcCommand(unsigned char cmd, unsigned long int argument);
void spiInit()
PORTB.7=1; // set SCK hi
DDRB.7=1; // set SCK as output
DDRB.6=0; // set MISO as input
DDRB.5=1; // set MOSI as output
DDRB.4=1; // SS must be output for Master mode to work
// SPI initialization
// SPI Type: Master
// SPI Clock Rate: 250.000 kHz
// SPI Clock Phase: Cycle Half
// SPI Clock Polarity: Low
// SPI Data Order: MSB First
SPCR=0x52;
SPSR=0x00;
unsigned char spiTransferByte(unsigned char data)
unsigned char received = 0;
SPDR = data;
while(!(SPSR & (1<<7)));
received = SPDR;
return (received);
void mmcInit(void)
// initialize SPI interface
spiInit();
// release chip select
MMC_CS_DDR.MMC_CS_PIN=1;
MMC_CS_PORT.MMC_CS_PIN=1;
unsigned char i;
unsigned char retry;
unsigned char r1=0;
retry = 0;
do
// send dummy bytes with CS high before accessing
for(i=0;i<10;i++) spiTransferByte(0xFF);
// resetting card, go to SPI mode
r1 = mmcSendCommand(MMC_GO_IDLE_STATE, 0);
retry++;
if(retry>10) return -1;
} while(r1 != 0x01);
retry = 0;
do
// initializing card for operation
r1 = mmcSendCommand(MMC_SEND_OP_COND, 0);
retry++;
if(retry>100) return -1;
} while(r1);
// turn off CRC checking to simplify communication
r1 = mmcSendCommand(MMC_CRC_ON_OFF, 0);
// set block length to 512 bytes
r1 = mmcSendCommand(MMC_SET_BLOCKLEN, 512);
return 0;
unsigned char r1;
// assert chip select
MMC_CS_PORT.MMC_CS_PIN=0;
// issue the command
r1 = mmcCommand(cmd, argument);
return r1;
unsigned char r1;
unsigned int i;
r1 = mmcCommand(MMC_READ_SINGLE_BLOCK, sector<<9);
// check for valid response
if(r1 != 0x00)
return r1;
// wait for block start
while(spiTransferByte(0xFF) != MMC_STARTBLOCK_READ);
// read in data
for(i=0; i<0x200; i++)
*buffer++ = spiTransferByte(0xFF);
// read 16-bit CRC
return 0;
unsigned char r1;
unsigned int i;
// issue command
r1 = mmcCommand(MMC_WRITE_BLOCK, sector<<9);
if(r1 != 0x00)
return r1;
// send dummy
// send data start token
spiTransferByte(MMC_STARTBLOCK_WRITE);
// write data
for(i=0; i<512; i++)
spiTransferByte(*buffer++);
// write 16-bit CRC (dummy values)
// read data response token
r1 = spiTransferByte(0xFF);
if( (r1&MMC_DR_MASK) != MMC_DR_ACCEPT)
return r1;
while(!spiTransferByte(0xFF));
// return success
return 0;
unsigned char r1;
unsigned char retry=0;
//send command
spiTransferByte(cmd | 0x40);
spiTransferByte(argument>>24);
spiTransferByte(argument>>16);
spiTransferByte(argument>>8);
spiTransferByte(argument);
spiTransferByte(0x95); // crc valid only for MMC_GO_IDLE_STATE
// end command
// wait for response
// if more than 8 retries, card has timed-out
// return the received 0xFF
while((r1 = spiTransferByte(0xFF)) == 0xFF)
if(retry++ > 8) break;
// return response
return r1;
char write_buf[512],read_buf[512];
void main(void)
unsigned int i;
unsigned long int sector;
mmcInit();
mmcReset();
for(i=0;i<512;i++)
write_buf[i]=i;
sector=5; //sector 5
mmcWrite(sector,write_buf); // write to sector 5
delay_ms(1);
mmcRead(sector,read_buf); // read of sector 5
while(1);
