پاسخ : مشکل spi در bascom....
:eek:
خیلی جالبه. حالا یه کار دیگه بکن. Phase رو تو Slave یک کن.
تف به این زندگی!!!!!!!!!!!!
Config Spi = Hard , Interrupt = off , Data Order = Lsb , Master = Yes , Polarity = High , Phase = 0, Clockrate = 128 Dim A As Byte Spiinit For A = 0 To 10 Spiout A , 1 waitms 30 Next A در slave : Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = No , Polarity = High , Phase = 0 , Clockrate = 128 Dim A As Byte dim b As Byte Spiinit Cls for b=0 to 10 disable spi Enable Spi Spiinit Spiin A , 1 Lcd A next b End
