پاسخ : پاسخ : تولید موج سینوسی با AVR
نه این روش خیلی کیفیت بالاتری نسبت به PWM داره
نوشته اصلی توسط حامد رحیمی
#include <mega8.h>
volatile unsigned char Delay;
flash unsigned char sine[256]={
0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,
0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,
0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf5,
0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,
0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,0xdc,
0xda,0xd8,0xd5,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb3,
0xb0,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x98,0x95,0x92,0x8f,0x8c,0x89,0x86,0x83,
0x80,0x7c,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x63,0x60,0x5d,0x5a,0x57,0x54,0x51,
0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x38,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,
0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x12,0x10,0x0f,0x0d,0x0c,0x0a,
0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08,
0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1b,0x1d,0x1f,0x21,0x23,
0x25,0x27,0x2a,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3e,0x40,0x43,0x46,0x49,0x4c,
0x4f,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x67,0x6a,0x6d,0x70,0x73,0x76,0x79,0x7c};
interrupt [TIM2_COMP] void timer2_comp_isr(void)
static unsigned char index=0;
if(!--Delay)
Delay=(ADCH?ADCH:1);
OCR1A=sine[++index];
OCR1B=sine[index];
void main(void)
DDRB=0x06;
ADMUX=0x60;
ADCSRA=0xE6;
while(!ADCSRA.4);
OCR1A=sine[0];
OCR1B=sine[0];
TCCR1A=0xB1;
TCCR1B=0x01;
TCCR2=0x09;
OCR2=63;
TIMSK=0x80;
#asm("sei")
while (1);
/* Written by : OZHAN KD - www.KnowledgePlus.ir
50Hz sinusoidal PWM output on OCR1A
Carrier frequency = 15.68 KHz
Sine frequency = 400Hz
PWM resolution = 8bit
mega32 oscillator frequency = 8MHz
#include <mega32.h>
interrupt [TIM0_COMP] void timer0_compare_isr(void)
OCR1A=sine[index++];
void main(void)
DDRD=1<<PORTD5;
OCR1A=sine[0];
TCCR1A=(1<<COM1A1)|(1<<WGM10);
TCCR1B=1<<CS10;// 8bit Phase correct PWM
OCR1B=78;
// TCCR0=(1<<WGM01)|(1<<CS00); // CTC
TIMSK=1<<OCIE1;
// فعال کردن وقفه کلی با ست کردن بیت هفتم رجیستر sreg
#asm("sei")
while (1);
