پاسخ : کتابخانهآای برای چیپ AD7730
سلام علی جان این کد میفرستم یه نگاه به دیتا شیت میکرو با 7730 می اندازی ببینی مشکل چیه
// DAC module connections
sbit Chip_Select at RC0_bit;
sbit Chip_Select_Direction at TRISC0_bit;
sbit rdy at RB7_bit;
sbit rdy_select at TRISB7_bit;
// End DAC module connections
sbit LCD_RS at RB5_bit;
sbit LCD_EN at RB4_bit;
sbit LCD_D4 at RB3_bit;
sbit LCD_D5 at RB2_bit;
sbit LCD_D6 at RB1_bit;
sbit LCD_D7 at RB0_bit;
sbit LCD_RS_Direction at TRISB5_bit;
sbit LCD_EN_Direction at TRISB4_bit;
sbit LCD_D4_Direction at TRISB3_bit;
sbit LCD_D5_Direction at TRISB2_bit;
sbit LCD_D6_Direction at TRISB1_bit;
sbit LCD_D7_Direction at TRISB0_bit;
unsigned int as,qe,vazn,buffer;
char txet[9],txet1[9];
// DAC increments (0..4095) --> output voltage (0..Vref)
void main() {
Chip_Select_Direction = 0;
rdy_select=1;
PWM1_Init(4915200);
PWM1_Start();
PWM1_Set_Duty(127);
Delay_ms(1000);
Lcd_Init();
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_END, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
CKP_bit=0;
CKE_bit=0;
Chip_Select=0;
Delay_ms(1);
SPI1_Write(0b11111111);
Chip_Select=1;
Chip_Select=0;
Delay_ms(1);
SPI1_Write(0b00000011);
SPI1_Write(0b10000000);
SPI1_Write(0b00000000);
Chip_Select=1;
Chip_Select=0;
// Delay_ms(1);
// SPI1_Write(0b00000100);
//SPI1_Write(0b00100011);
//Chip_Select=1;
Chip_Select=0;
// Delay_ms(1);
SPI1_Write(0b00000010);
SPI1_Write(0b00100000);
SPI1_Write(0b10010000);
Chip_Select=1;
//Chip_Select=0;
// Delay_ms(1);
//SPI1_Write(0b00100001);
//Chip_Select=1;
while(1) {
if(rdy=0) {
Chip_Select=0;
SPI1_Write(0b00010001);
Delay_ms(10);
as=SPI1_Read(0);
qe=SPI1_Read(0);
Chip_Select=1;
Delay_ms(80);
vazn=as+(qe*256);
WordToStr(as, txet);
WordToStr(qe, txet1);
// Lcd_Out(1, 1, "txet");
Lcd_Out(1, 1, txet);
Lcd_Out(2, 1, txet1);
}[left][/left]
