من میخواستم وقتی دو کلید وصل شه دستواتم رو بخونه ولی نشد لطفا راهنمایی کنید
$regfile = "m8def.dat" $crystal = 1000000 Config Portc = Output Config Portb = &B11111111 '---------wait for active ------- Main: Do Reset Portc.0 If Pinb.&B00000011 = 1 Then Gosub Pv12start 'p1&p2&v1&v2 chek If Pinb.&B00000001 = 1 Then Gosub Pv1start 'p1&v1 chek If Pinb.&B00000010 = 1 Then Gosub Pv2start 'p2&v2 chek If Pinb.&B00000100 = 1 Then Gosub Basket 'basket chek Loop End '-------pump val 1------ Pv1start: Do Set Portc.0 Set Portc.1 If Pinb.&B00000000 = 1 Then Gosub P1off Loop End '---------------pump off ---- P1off: Do Reset Portc.0 Waitms 1500 Goto V1off Loop '----------------val1 off ----- V1off: Do Reset Portc.1 If Pinb.&B00000100 = 1 Then Gosub Basket 'basket chek If Pinb.&B00000000 = 1 Then Gosub Main If Pinb.&B00000011 = 1 Then Gosub Pv12start Loop '-------pump val 2------ Pv2start: Do Set Portc.2 Set Portc.3 If Pinb.&B00000000 = 1 Then Gosub P2off Loop End '---------------pump2 off ---- P2off: Do Reset Portc.2 Waitms 1500 Goto V2off Loop '----------------val2 off ----- V2off: Do Reset Portc.3 If Pinb.&B00000100 = 1 Then Gosub Basket 'basket chek If Pinb.&B00000000 = 1 Then Gosub Main If Pinb.&B00000011 = 1 Then Gosub Pv12start Loop '-------pump val 1 & pump val 2 ------ Pv12start: Do Reset Portc.4 Set Portc.0 Set Portc.1 Set Portc.2 Set Portc.3 If Pinb.&B00000000 = 1 Then Gosub P12off If Pinb.&B00000001 = 1 Then Gosub P12off Loop End '---------------pump2 off ---- P12off: Do Reset Portc.0 Reset Portc.2 Waitms 1500 Goto V12off Loop '----------------val2 off ----- V12off: Do Reset Portc.1 Reset Portc.3 If Pinb.&B00000001 = 1 Then Gosub Pv1start Loop '-------basket ------ '-------ON -BASKET------ Basket: Set Portc.4 Wait 5 If Pinb.&B00000000 = 1 Then Gosub Offbasket Set Portc.0 Set Portc.1 Set Portc.2 Set Portc.3 Wait 5 Do If Pinb.&B00000011 = 1 Then Gosub Pv12start If Pinb.&B00000000 = 1 Then Gosub Offbasket Loop End '---------------off -basket---- Offbasket: Do Wait 10 Reset Portc.4 Goto Main Loop End
