مشکل با Cubeide
    مشکل با Cubeide
    سلام وقت بخیر دوستان
    یه برنامه نوشتم ولی کامپایلر ارور میده
    [HASHTAG="t15999"]include[/HASHTAG] "main.h"
    [HASHTAG="t15999"]include[/HASHTAG] "cmsis_os.h"
    [HASHTAG="t15999"]include[/HASHTAG] <string.h>
    UART_HandleTypeDef huart2;
    void SystemClock_Config(void);
    static void MX_GPIO_Init(void);
    static void MX_USART2_UART_Init(void);
    int main(void)
    HAL_Init();
    SystemClock_Config();
    MX_GPIO_Init();
    MX_USART2_UART_Init();
    while (1)
    char str[] = "FaraDars\n";
    HAL_UART_Transmit(&huart2, (uint8_t*)str, strlen(str), HAL_MAX_DELAY);
    HAL_Delay(500);
    * @brief System Clock Configuration
    * @retval None
    RCC_OscInitTypeDef RCC_OscInitStruct = {0};
    RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
    /** Configure the main internal regulator output voltage
    __HAL_RCC_PWR_CLK_ENABLE();
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLT AGE_SCALE2);
    /** Initializes the RCC Oscillators according to the specified parameters
    * in the RCC_OscInitTypeDef structure.
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
    RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
    RCC_OscInitStruct.PLL.PLLM = 4;
    RCC_OscInitStruct.PLL.PLLN = 84;
    RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
    RCC_OscInitStruct.PLL.PLLQ = 4;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
    /** Initializes the CPU, AHB and APB buses clocks
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
    |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
    * @brief USART2 Initialization Function
    * @param None
    * @retval None
    /* USER CODE BEGIN USART2_Init 0 */
    /* USER CODE END USART2_Init 0 */
    /* USER CODE BEGIN USART2_Init 1 */
    /* USER CODE END USART2_Init 1 */
    huart2.Instance = USART2;
    huart2.Init.BaudRate = 115200;
    huart2.Init.WordLength = UART_WORDLENGTH_8B;
    huart2.Init.StopBits = UART_STOPBITS_1;
    huart2.Init.Parity = UART_PARITY_NONE;
    huart2.Init.Mode = UART_MODE_TX_RX;
    huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    huart2.Init.OverSampling = UART_OVERSAMPLING_16;
    if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
    /* USER CODE BEGIN USART2_Init 2 */
    /* USER CODE END USART2_Init 2 */
    * @brief GPIO Initialization Function
    * @param None
    * @retval None
    /* USER CODE BEGIN MX_GPIO_Init_1 */
    /* USER CODE END MX_GPIO_Init_1 */
    /* GPIO Ports Clock Enable */
    __HAL_RCC_GPIOH_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /* USER CODE BEGIN MX_GPIO_Init_2 */
    /* USER CODE END MX_GPIO_Init_2 */
    /* USER CODE BEGIN 4 */
    /* USER CODE END 4 */
    /* USER CODE BEGIN Header_StartDefaultTask */
    * @brief Function implementing the defaultTask thread.
    * @param argument: Not used
    * @retval None
    /* USER CODE END Header_StartDefaultTask */
    void StartDefaultTask(void *argument)
    /* USER CODE BEGIN 5 */
    /* Infinite loop */
    for(;;)
    osDelay(1);
    /* USER CODE END 5 */
    * @brief Period elapsed callback in non blocking mode
    * [USER="146394"]note[/USER] This function is called when TIM1 interrupt took place, inside
    * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
    * a global variable "uwTick" used as application time base.
    * @param htim : TIM handle
    * @retval None
    void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
    /* USER CODE BEGIN Callback 0 */
    /* USER CODE END Callback 0 */
    if (htim->Instance == TIM1) {
    HAL_IncTick();
    /* USER CODE BEGIN Callback 1 */
    /* USER CODE END Callback 1 */
    * @brief This function is executed in case of error occurrence.
    * @retval None
    void Error_Handler(void)
    /* USER CODE BEGIN Error_Handler_Debug */
    /* User can add his own implementation to report the HAL error return state */
    __disable_irq();
    while (1)
    /* USER CODE END Error_Handler_Debug */
    #ifdef USE_FULL_ASSERT
    * @brief Reports the name of the source file and the source line number
    * where the assert_param error has occurred.
    * @param file: pointer to the source file name
    * @param line: assert_param error line source number
    * @retval None
    void assert_failed(uint8_t *file, uint32_t line)
    /* USER CODE BEGIN 6 */
    /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
    /* USER CODE END 6 */
    [HASHTAG="t25972"]endif[/HASHTAG] /* USE_FULL_ASSERT */
    ارور ها یکیش اینه
    ../Drivers/CMSIS/RTOS2/Source/os_systick.c:25:10: fatal error: os_tick.h: No such file or directory
    include "os_tick.h"
    ممنون میشم کمک کنید
    جدیدترین ویرایش توسط mk9000; ۱۸:۱۴ ۱۴۰۴/۰۹/۲۸.
    لطفا کمک کنید
    هزینه هم بخواین تقدیم می کنم ده روزه نمی تونم اینو کامپایل کنم
      نوشته اصلی توسط mk9000 نمایش پست ها
      int main(void)
      HAL_Init();
      MX_GPIO_Init();
      while (1)
      HAL_Delay(500);
      * @retval None
      Error_Handler();
      Error_Handler();
      * @param None
      * @retval None
      Error_Handler();
      * @param None
      * @retval None
      * @retval None
      /* Infinite loop */
      for(;;)
      osDelay(1);
      * @retval None
      HAL_IncTick();
      * @retval None
      __disable_irq();
      while (1)
      * @retval None
      ارور ها یکیش اینه
      include "os_tick.h"
      ممنون میشم کمک کنید
      درود بر شما،
      به نظر میرسه داخل برنامه شما از RTOS استفاده شده ولی کتابخانه هاش ناقص دانلود شده ( یا اصلا دانلود نشده ) و باید خودتون دانلود و اضافه کنید.
      به وضوح مشخصه که کامپایلر فایل هدر os_tick.h رو نمیتونه پیدا کنه.
        ممنون از راهنمایی تون
        موقع ایجاد پروژه با کیوبمکس
        تیک گزینه افزودن لایبری رو نمیزدم
        زدم خودش خودکار اضاف کرد و درست شد
